Saltar al contenido principal
LG Rebel Rear Camera Replacement
Qué necesitas
  1. LG Rebel Rear Camera Replacement, Rear Camera: paso 1, imagen 1 de 2 LG Rebel Rear Camera Replacement, Rear Camera: paso 1, imagen 2 de 2
    • Turn the phone on its side and locate the small groove.
    • Use the plastic opening tool to take the back cover off of the phone.
  2. LG Rebel Rear Camera Replacement: paso 2, imagen 1 de 3 LG Rebel Rear Camera Replacement: paso 2, imagen 2 de 3 LG Rebel Rear Camera Replacement: paso 2, imagen 3 de 3
    • Locate the small groove on the back of the phone near the bottom.
    • Use the metal spudger to pop open the black plastic covering.
    • Remove black plastic covering.
  3. LG Rebel Rear Camera Replacement: paso 3, imagen 1 de 2 LG Rebel Rear Camera Replacement: paso 3, imagen 2 de 2
    • Use the metal spudger to pop up the black plastic covering near top of phone.
    • Remove the black plastic covering.
  4. LG Rebel Rear Camera Replacement: paso 4, imagen 1 de 3 LG Rebel Rear Camera Replacement: paso 4, imagen 2 de 3 LG Rebel Rear Camera Replacement: paso 4, imagen 3 de 3
    • Locate the connective pieces on the back of the phone.
    • Use the metal spudger to disconnect both of the connective pieces from the back.
  5. LG Rebel Rear Camera Replacement: paso 5, imagen 1 de 3 LG Rebel Rear Camera Replacement: paso 5, imagen 2 de 3 LG Rebel Rear Camera Replacement: paso 5, imagen 3 de 3
    • Flip the phone over so the screen is facing up.
    • Slide the metal spudger around the perimeter of the phone until the entire seal has been broken.
    • Use the small suction cup to remove the screen.
  6. LG Rebel Rear Camera Replacement: paso 6, imagen 1 de 2 LG Rebel Rear Camera Replacement: paso 6, imagen 2 de 2
    • Locate the black bumper at the bottom of the front of the phone.
    • Use the metal spudger to slide the bumper out.
  7. LG Rebel Rear Camera Replacement: paso 7, imagen 1 de 3 LG Rebel Rear Camera Replacement: paso 7, imagen 2 de 3 LG Rebel Rear Camera Replacement: paso 7, imagen 3 de 3
    • Use the metal spudger to carefully loosen the motherboard from the body of the phone.
    • Slowly slide the motherboard out of the body of the phone.
    • Remove the motherboard.
  8. LG Rebel Rear Camera Replacement: paso 8, imagen 1 de 2 LG Rebel Rear Camera Replacement: paso 8, imagen 2 de 2
    • Locate the rear camera on the motherboard.
    • Use the metal spudger to disconnect the connective piece at the base of the camera.
    • Remove the camera.
Conclusión
Una persona más ha completado esta guía.
Emma Johnson
Miembro Desde 02/08/18
184 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 8
Todo El Tiempo: 487
