Saltar al contenido principal
LG Rebel Motherboard Replacement
Qué necesitas
  1. LG Rebel Motherboard Replacement, Motherboard: paso 1, imagen 1 de 2 LG Rebel Motherboard Replacement, Motherboard: paso 1, imagen 2 de 2
    • Insert the plastic opening tool into the small groove on the side of the phone.
    • Remove the back cover with the plastic opening tool.
  2. LG Rebel Motherboard Replacement: paso 2, imagen 1 de 3 LG Rebel Motherboard Replacement: paso 2, imagen 2 de 3 LG Rebel Motherboard Replacement: paso 2, imagen 3 de 3
    • Insert the metal spudger into the small groove on the back of the phone.
    • Lift and remove the black plastic covering with the metal spudger.
  3. LG Rebel Motherboard Replacement: paso 3, imagen 1 de 2 LG Rebel Motherboard Replacement: paso 3, imagen 2 de 2
    • Use the metal spudger to lift the remaining black plastic cover pieces.
  4. LG Rebel Motherboard Replacement: paso 4, imagen 1 de 3 LG Rebel Motherboard Replacement: paso 4, imagen 2 de 3 LG Rebel Motherboard Replacement: paso 4, imagen 3 de 3
    • Use the metal spudger to lift and disconnect the two connective pieces on the back of the phone.
  5. LG Rebel Motherboard Replacement: paso 5, imagen 1 de 3 LG Rebel Motherboard Replacement: paso 5, imagen 2 de 3 LG Rebel Motherboard Replacement: paso 5, imagen 3 de 3
    • Flip the phone, so that the screen is facing upwards.
    • Slide the metal spudger along the perimeter of the phone in order to break the entire seal.
    • Use the suction cup to lift and remove the screen.
  6. LG Rebel Motherboard Replacement: paso 6, imagen 1 de 2 LG Rebel Motherboard Replacement: paso 6, imagen 2 de 2
    • Use the metal spudger to slide the black bumper out from the bottom of the phone.
  7. LG Rebel Motherboard Replacement: paso 7, imagen 1 de 3 LG Rebel Motherboard Replacement: paso 7, imagen 2 de 3 LG Rebel Motherboard Replacement: paso 7, imagen 3 de 3
    • Use the metal spudger to carefully loosen the motherboard from the body of the phone.
    • Slowly slide the motherboard out of the body of the phone.
    • Remove the motherboard.
Conclusión
2 personas más completaron esta guía.
Un comentario
First time tearing apart a phone. His instructions are spot on. Pretty easy phone though.
Bruce Simmons - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 7
Todo El Tiempo: 1,576
