Saltar al contenido principal
LG Rebel Front Camera Replacement
Qué necesitas
  1. LG Rebel Front Camera Replacement, Front Camera: paso 1, imagen 1 de 3 LG Rebel Front Camera Replacement, Front Camera: paso 1, imagen 2 de 3 LG Rebel Front Camera Replacement, Front Camera: paso 1, imagen 3 de 3
    • Turn phone over to its front side.
    • Use a spudger to begin removing the screen by the right hand corner. Begin to move the tool around the edges of the screen.
  2. LG Rebel Front Camera Replacement: paso 2, imagen 1 de 3 LG Rebel Front Camera Replacement: paso 2, imagen 2 de 3 LG Rebel Front Camera Replacement: paso 2, imagen 3 de 3
    • Once you have loosened the grip around the edges, pop off the screen using a suction cup.
    • Once the front screen is removed, place the phone on its side and find the groove located on the side.
    • Use the plastic opening tool to pop open the black plastic covering.
    • Remove black plastic cover.
  3. LG Rebel Front Camera Replacement: paso 3, imagen 1 de 3 LG Rebel Front Camera Replacement: paso 3, imagen 2 de 3 LG Rebel Front Camera Replacement: paso 3, imagen 3 de 3
    • Locate the small groove on the back of the phone near the bottom.
    • Use the metal spudger to pop open the black plastic covering.
    • Remove black plastic covering.
  4. LG Rebel Front Camera Replacement: paso 4, imagen 1 de 2 LG Rebel Front Camera Replacement: paso 4, imagen 2 de 2
    • Use the metal spudger to pop up the black plastic covering near top of phone.
    • Remove the black plastic covering.
  5. LG Rebel Front Camera Replacement: paso 5, imagen 1 de 3 LG Rebel Front Camera Replacement: paso 5, imagen 2 de 3 LG Rebel Front Camera Replacement: paso 5, imagen 3 de 3
    • Remove the motherboard with a spudger.
    • Slowly begin to lift motherboard with your hand carefully.
    • Once the motherboard is completely off, set the phone to the side and focus on the small black box with a square tail (which is the front camera).
  6. LG Rebel Front Camera Replacement: paso 6, imagen 1 de 2 LG Rebel Front Camera Replacement: paso 6, imagen 2 de 2
    • Remove the front camera by its tail with a spudger.
Conclusión
Una persona más ha completado esta guía.
Lesley Sigaran
Miembro Desde 02/08/18
145 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 4
Ultimos 30 días: 7
Todo El Tiempo: 357
