Saltar al contenido principal
LG Rebel 4 LTE Disassembly
Qué necesitas
  1. LG Rebel 4 LTE Disassembly, Remove the Cover: paso 1, imagen 1 de 2 LG Rebel 4 LTE Disassembly, Remove the Cover: paso 1, imagen 2 de 2
    • Locate the indent on the back left side of the phone.
    • Insert the opening tool into the indent and pry until it pops.
    • Remove the backing.
  2. LG Rebel 4 LTE Disassembly, Remove Internal Components: paso 2, imagen 1 de 3 LG Rebel 4 LTE Disassembly, Remove Internal Components: paso 2, imagen 2 de 3 LG Rebel 4 LTE Disassembly, Remove Internal Components: paso 2, imagen 3 de 3
    • Use the spudger to pry the battery out.
    • If installed, pop out the SD/TF card by gently pressing in and releasing the SD card. Not pictured, Located above the Sims card (See Below).
    • Use your fingers to remove the sim card.
  3. LG Rebel 4 LTE Disassembly, Remove Screws: paso 3, imagen 1 de 3 LG Rebel 4 LTE Disassembly, Remove Screws: paso 3, imagen 2 de 3 LG Rebel 4 LTE Disassembly, Remove Screws: paso 3, imagen 3 de 3
    • Using the #000 Phillips screwdriver, remove all the screws (as seen in the photo).
    • There should be 12 screws in total.
    • Don't lose the screws!
  4. LG Rebel 4 LTE Disassembly, Remove Charging Port Cover: paso 4, imagen 1 de 2 LG Rebel 4 LTE Disassembly, Remove Charging Port Cover: paso 4, imagen 2 de 2
    • Use the spudger to carefully pry the cover around the charging port.
  5. LG Rebel 4 LTE Disassembly, Remove the Screen: paso 5, imagen 1 de 3 LG Rebel 4 LTE Disassembly, Remove the Screen: paso 5, imagen 2 de 3 LG Rebel 4 LTE Disassembly, Remove the Screen: paso 5, imagen 3 de 3
    • Rotate the phone (view picture) to reveal the top corner of the phone.
    • Using a opening pick, pry in between the glass screen and the framing.
  6. LG Rebel 4 LTE Disassembly, Remove the Motherboard: paso 6, imagen 1 de 3 LG Rebel 4 LTE Disassembly, Remove the Motherboard: paso 6, imagen 2 de 3 LG Rebel 4 LTE Disassembly, Remove the Motherboard: paso 6, imagen 3 de 3
    • Pry from the top and bottom of the screen with the (refer to photo) opening pick to release the tabs holding the motherboard to the phone.
    • Do not let the main camera fall out while removing the mother board.
  7. LG Rebel 4 LTE Disassembly, Disconnect the Connector Cable: paso 7, imagen 1 de 3 LG Rebel 4 LTE Disassembly, Disconnect the Connector Cable: paso 7, imagen 2 de 3 LG Rebel 4 LTE Disassembly, Disconnect the Connector Cable: paso 7, imagen 3 de 3
    • On the bottom right of the phone, locate a cable that holds the motherboard to the phone.
    • Disconnect the cable by gently pulling up on the component with your fingers.
    • Do not use a prying tool or screwdriver to disconnect the cable.
  8. LG Rebel 4 LTE Disassembly, Remove the Camera: paso 8, imagen 1 de 3 LG Rebel 4 LTE Disassembly, Remove the Camera: paso 8, imagen 2 de 3 LG Rebel 4 LTE Disassembly, Remove the Camera: paso 8, imagen 3 de 3
    • Separate the camera from the magnet by gently pulling up.
  9. LG Rebel 4 LTE Disassembly, Disassembly Complete: paso 9, imagen 1 de 1
    • Congratulations. You've successfully disassembled your device.
    • To reassemble the device, follow these steps in reverse order. (Begin with step 8, continuining until you end on step 1.
    • When reassembling, make sure that each component snaps tightly to the phone before moving to the next step.
Conclusión
JCJR
Miembro Desde 06/23/23
169 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 21
Todo El Tiempo: 373
