Saltar al contenido principal
LG Realm Rear Facing Camera Replacement
Qué necesitas
  1. LG Realm Rear Facing Camera Replacement, Battery: paso 1, imagen 1 de 2 LG Realm Rear Facing Camera Replacement, Battery: paso 1, imagen 2 de 2
    • To remove the back, insert thumbnail into MicroUSB port, and pull up to loosen back.
    • Use nail to loosen case on all four sides. Once loose, remove back case.
  2. LG Realm Rear Facing Camera Replacement: paso 2, imagen 1 de 1
    • Insert thumbnail into tab below battery.
    • Pull away from phone and remove.
  3. LG Realm Rear Facing Camera Replacement, Plastic Midframe: paso 3, imagen 1 de 2 LG Realm Rear Facing Camera Replacement, Plastic Midframe: paso 3, imagen 2 de 2
    • Once the back cover and battery are removed, use the Phillips #J000 screwdriver to remove all 11 screws located around the plastic midframe.
  4. LG Realm Rear Facing Camera Replacement: paso 4, imagen 1 de 1
    • Using the plastic opening tool, carefully pry and separate the plastic midframe from the rest of the phone.
  5. LG Realm Rear Facing Camera Replacement, Rear Facing Camera: paso 5, imagen 1 de 1
    • Locate the rear facing camera.
    • Using the plastic opening tool, pry apart the cable from where it connects to the phone.
  6. LG Realm Rear Facing Camera Replacement: paso 6, imagen 1 de 1
    • After removing the ribbon cable, the camera should be easy to remove with your fingers. Remove the rear facing camera.
Conclusión
2 personas más completaron esta guía.
Emily Palmer
Miembro Desde 03/07/16
287 Reputación
1 Guía escrita
Equipo
Marist, Team 1-5, Laflen Spring 2016 Miembro de Marist, Team 1-5, Laflen Spring 2016
MARS-LAFLEN-S16S1G5
2 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 5
Ultimos 30 días: 14
Todo El Tiempo: 266
