Saltar al contenido principal
LG Realm Front Facing Camera Replacement
Qué necesitas
  1. LG Realm Front Facing Camera Replacement, Battery: paso 1, imagen 1 de 2 LG Realm Front Facing Camera Replacement, Battery: paso 1, imagen 2 de 2
    • To remove the back, insert thumbnail into MicroUSB port, and pull up to loosen back.
    • Use nail to loosen case on all four sides. Once loose, remove back case.
  2. LG Realm Front Facing Camera Replacement: paso 2, imagen 1 de 1
    • Insert thumbnail into tab below battery.
    • Pull away from phone and remove.
  3. LG Realm Front Facing Camera Replacement, Plastic Midframe: paso 3, imagen 1 de 2 LG Realm Front Facing Camera Replacement, Plastic Midframe: paso 3, imagen 2 de 2
    • Once the back cover and battery are removed, use the Phillips #J000 screwdriver to remove all 11 screws located around the plastic midframe.
  4. LG Realm Front Facing Camera Replacement: paso 4, imagen 1 de 1
    • Using the plastic opening tool, carefully pry and separate the plastic midframe from the rest of the phone.
  5. LG Realm Front Facing Camera Replacement, Front Facing Camera: paso 5, imagen 1 de 1
    • Locate the front facing camera in the top left hand corner of the motherboard. Using the plastic opening tool, separate the ribbon cable from the phone.
  6. LG Realm Front Facing Camera Replacement: paso 6, imagen 1 de 1
    • After removing this ribbon cable, you will be able to easily remove the front facing camera with your fingers.
Conclusión
4 personas más completaron esta guía.
Equipo
Marist, Team 1-5, Laflen Spring 2016 Miembro de Marist, Team 1-5, Laflen Spring 2016
MARS-LAFLEN-S16S1G5
2 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 4
Ultimos 30 días: 12
Todo El Tiempo: 416
