Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
LG Power Screen Replacement
Qué necesitas
  1. LG Power Screen Replacement, Battery: paso 1, imagen 1 de 2 LG Power Screen Replacement, Battery: paso 1, imagen 2 de 2
    • Slide a plastic spudger, or guitar pick, between the back and front panel at the bottom .
    • A metal spudger can easily damage your device. A plastic opening tool is always the only option.
  2. LG Power Screen Replacement: paso 2, imagen 1 de 2 LG Power Screen Replacement: paso 2, imagen 2 de 2
    • Carefully pop the back panel off and place it to the side.
  3. LG Power Screen Replacement: paso 3, imagen 1 de 2 LG Power Screen Replacement: paso 3, imagen 2 de 2
    • Use the thumb tab to remove the battery.
  4. LG Power Screen Replacement, Motherboard: paso 4, imagen 1 de 1
    • Remove the eight 4mm screws along the side of the mid panel using the Phillips #000 screwdriver head.
  5. LG Power Screen Replacement: paso 5, imagen 1 de 2 LG Power Screen Replacement: paso 5, imagen 2 de 2
    • Slide a plastic opening tool between the mid and front panel to remove the middle panel.
    • Place the mid panel to the side.
  6. LG Power Screen Replacement: paso 6, imagen 1 de 3 LG Power Screen Replacement: paso 6, imagen 2 de 3 LG Power Screen Replacement: paso 6, imagen 3 de 3
    • Detach the motherboard and touchscreen from each other by using a plastic opening tool.
    • The motherboard will then be free from the phone.
  7. LG Power Screen Replacement, Screen: paso 7, imagen 1 de 3 LG Power Screen Replacement, Screen: paso 7, imagen 2 de 3 LG Power Screen Replacement, Screen: paso 7, imagen 3 de 3
    • After removing the motherboard, slide a thin plastic opening tool between the screen and the frame.
    • This step may take awhile, because of the glue keeping the frame and screen together.
Conclusión
12 personas más completaron esta guía.
Equipo
USF Tampa, Team 4-6, Lacy Spring 2016 Miembro de USF Tampa, Team 4-6, Lacy Spring 2016
USFT-LACY-S16S4G6
Miembros de 4
10 Guías creadas
9Guía Comentarios
do i need a replacement screen?
jj - Contestar Compartir
My screen is shattered otherwise the phone works fine..touch works and screen under glass is good. I want to replace the screen myself but my question is are the screen and digitizer fused (one piece) or can I just replace the glass screen? For an LG power x
Nikki - Contestar Compartir
Did you ever figure out if there the same or separate. I'm needing to do the same.
sarahelizabeth0526 - Contestar Compartir
Where do I buy the glass panel?
Liam McBride - Contestar Compartir
i got the glass screen at amazonbot most digitisers have a ribbon wire to connecttheres doesnt..not sure if its just held on with 2 face tape??
Peter Maggiop - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 22
Ultimos 30 días: 73
Todo El Tiempo: 26,556
