Introducción
This guide is made to help remove the motherboard from your phone if you are having problems with it or need to replace it. The only real hazard involving this step is removing the back and mid plating of your phone.
Qué necesitas
Slide a plastic spudger, or guitar pick, between the back and front panel at the bottom .
Remove the eight 4mm screws along the side of the mid panel using the Phillips #000 screwdriver head.
2 personas más completaron esta guía.
