Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Introducción
If you need to install a new outside trim on your LG Phoenix 2, use this guide to disassemble and replace the damaged outer trim. For this guide you will need a plastic opening tool and a Phillips #000 screwdriver head. These steps will be straightforward and easy to follow, but the pieces should be handled with care, so as to not damage or misplace any needed components.
Partes
No se especificaron partes.
  1. Insert a fingernail in the notch on the bottom right corner of the phone. Pop off the back cover off of your device.
    • Insert a fingernail in the notch on the bottom right corner of the phone.
    • Pop off the back cover off of your device.
  2. Insert a fingernail in the notch under the battery. Remove the battery.
    • Insert a fingernail in the notch under the battery.
    • Remove the battery.
  3. Essential Electronics Toolkit
    Pequeño juego de herramientas. Grandes posibilidades.
    Shop Toolkits
    Essential
    Electronics
    Toolkit
    Shop Toolkits
  4. Insert the opening tool under the bottom cover. Pop out the bottom cover.
    • Insert the opening tool under the bottom cover.
    • Pop out the bottom cover.
  5. Remove eight 3mm screws using a Phillips #0 screwdriver.
    • Remove eight 3mm screws using a Phillips #0 screwdriver.
  6. Insert the opening tool in between the silver trim and the screen. Pop off the trim.
    • Insert the opening tool in between the silver trim and the screen.
    • Pop off the trim.
Conclusión
Una persona más ha completado esta guía.
Sarah Popp
Miembro Desde 26/11/18
392 Reputación
3 Guías creadas
Equipo
IUPUI, Team S7-G7, Wilson Fall 2018 Miembro de IUPUI, Team S7-G7, Wilson Fall 2018
IUPUI-WILSON-F18S7G7
4 Miembros
3 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 89
