Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Introducción
If you need to install a new headphone jack on your LG Phoenix 2, use this guide to disassemble and replace the damaged part. For this guide you will need a plastic opening tool and a Phillips #000 screwdriver. These steps will be straightforward and easy to follow, but the pieces should be handled with care, so as to not damage or misplace any needed components.
Partes
No se especificaron partes.
  1. Insert a fingernail into the notch on the bottom right corner of the phone. Pop off the back cover off of your device.
    • Insert a fingernail into the notch on the bottom right corner of the phone.
    • Pop off the back cover off of your device.
  2. Insert a fingernail in the notch under the battery. Remove the battery.
    • Insert a fingernail in the notch under the battery.
    • Remove the battery.
  3. Essential Electronics Toolkit
    Pequeño juego de herramientas. Grandes posibilidades.
    Shop Toolkits
    Essential
    Electronics
    Toolkit
    Shop Toolkits
  4. Insert the opening tool under the bottom cover. Pop the bottom cover off.
    • Insert the opening tool under the bottom cover.
    • Pop the bottom cover off.
  5. Remove eight 3mm screws using a Phillips #0 screwdriver.
    • Remove eight 3mm screws using a Phillips #0 screwdriver.
  6. Insert the opening tool in between the phone screen and the silver trim. Pop off the trim.
    • Insert the opening tool in between the phone screen and the silver trim.
    • Pop off the trim.
  7. Insert a screwdriver into the headphone jack. Pop out the headphone jack.
    • Insert a screwdriver into the headphone jack.
    • Pop out the headphone jack.
Conclusión
Una persona más ha completado esta guía.
Sarah Popp
Miembro Desde 26/11/18
392 Reputación
3 Guías creadas
Equipo
IUPUI, Team S7-G7, Wilson Fall 2018 Miembro de IUPUI, Team S7-G7, Wilson Fall 2018
IUPUI-WILSON-F18S7G7
4 Miembros
3 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 12
Todo El Tiempo: 109
