Introducción
If you need to install a new front camera on your LG Phoenix 2, use this guide to disassemble and replace the damaged front camera. For this guide you will need a plastic opening tool and a Phillips #000 screwdriver head. These steps will be straightforward and easy to follow, but the pieces should be handled with care, so as to not damage or misplace any needed components.
Qué necesitas
Insert a fingernail into the notch on the bottom right corner of the phone.
Remove the back cover off of the device.
