Saltar al contenido principal
LG Phoenix 2 Charge Port Replacement
Qué necesitas
  1. LG Phoenix 2 Charge Port Replacement, Battery: paso 1, imagen 1 de 3 LG Phoenix 2 Charge Port Replacement, Battery: paso 1, imagen 2 de 3 LG Phoenix 2 Charge Port Replacement, Battery: paso 1, imagen 3 de 3
    • Place a fingernail in the notch at the bottom edge of the phone.
    • Pull on the back cover with one hand while keeping the rest of the phone steady, and run your fingernail along the edge.
  2. LG Phoenix 2 Charge Port Replacement: paso 2, imagen 1 de 3 LG Phoenix 2 Charge Port Replacement: paso 2, imagen 2 de 3 LG Phoenix 2 Charge Port Replacement: paso 2, imagen 3 de 3
    • Place a fingernail in the notch at the bottom edge of the battery.
    • Pull the battery out.
  3. LG Phoenix 2 Charge Port Replacement, Motherboard: paso 3, imagen 1 de 2 LG Phoenix 2 Charge Port Replacement, Motherboard: paso 3, imagen 2 de 2
    • Remove all nine of the 3.0mm screws on the back of the phone using a Phillips #0 screwdriver, including the one attaching the camera lens.
  4. LG Phoenix 2 Charge Port Replacement: paso 4, imagen 1 de 2 LG Phoenix 2 Charge Port Replacement: paso 4, imagen 2 de 2
    • With the plastic opening tool, pry between the screen and the outer chrome edge to remove the bottom shield from the rest of the phone.
  5. LG Phoenix 2 Charge Port Replacement: paso 5, imagen 1 de 3 LG Phoenix 2 Charge Port Replacement: paso 5, imagen 2 de 3 LG Phoenix 2 Charge Port Replacement: paso 5, imagen 3 de 3
    • With a plastic opening tool, disconnect all three ribbon connectors from the motherboard: one for the front camera, one for the rear camera, and one for the screen.
  6. LG Phoenix 2 Charge Port Replacement: paso 6, imagen 1 de 3 LG Phoenix 2 Charge Port Replacement: paso 6, imagen 2 de 3 LG Phoenix 2 Charge Port Replacement: paso 6, imagen 3 de 3
    • Using a plastic opening tool, separate the motherboard from the back frame and remove it from the device.
  7. LG Phoenix 2 Charge Port Replacement, Charge Port: paso 7, imagen 1 de 2 LG Phoenix 2 Charge Port Replacement, Charge Port: paso 7, imagen 2 de 2
  8. LG Phoenix 2 Charge Port Replacement: paso 8, imagen 1 de 3 LG Phoenix 2 Charge Port Replacement: paso 8, imagen 2 de 3 LG Phoenix 2 Charge Port Replacement: paso 8, imagen 3 de 3
    • Desolder the USB port from the motherboard and remove it from the device.
Conclusión
3 personas más completaron esta guía.
Alex Selsley
Miembro Desde 11/04/19
325 Reputación
2 Guías creadas
Equipo
IUPUI, Team S1-G1, Harley Fall 2019 Miembro de IUPUI, Team S1-G1, Harley Fall 2019
IUPUI-HARLEY-F19S1G1
3 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 4
Todo El Tiempo: 674
