Saltar al contenido principal
LG Optimus V Speaker Replacement
Qué necesitas
  1. LG Optimus V Speaker Replacement, Battery: paso 1, imagen 1 de 1
    • Turn the LG Optimus V over, so that the back cover is facing upward.
  2. LG Optimus V Speaker Replacement: paso 2, imagen 1 de 1
    • Locate the opening above the camera.
    • Use a spudger to detach the back cover.
  3. LG Optimus V Speaker Replacement: paso 3, imagen 1 de 3 LG Optimus V Speaker Replacement: paso 3, imagen 2 de 3 LG Optimus V Speaker Replacement: paso 3, imagen 3 de 3
    • Gently remove the battery with your spudger.
  4. LG Optimus V Speaker Replacement, Camera: paso 4, imagen 1 de 2 LG Optimus V Speaker Replacement, Camera: paso 4, imagen 2 de 2
    • Remove the six screws on the silver casing.
    • Use the plastic opening tool to remove the silver casing.
  5. LG Optimus V Speaker Replacement: paso 5, imagen 1 de 3 LG Optimus V Speaker Replacement: paso 5, imagen 2 de 3 LG Optimus V Speaker Replacement: paso 5, imagen 3 de 3
    • Use a plastic opening tool to remove each area holding the parts together.
  6. LG Optimus V Speaker Replacement: paso 6, imagen 1 de 2 LG Optimus V Speaker Replacement: paso 6, imagen 2 de 2
    • Use a plastic opening tool to remove the small black and yellow piece that reads Y3114C.
    • Use a plastic opening tool to pry off the camera.
  7. LG Optimus V Speaker Replacement, Speaker: paso 7, imagen 1 de 1
    • This is the area that holds the speaker.
  8. LG Optimus V Speaker Replacement: paso 8, imagen 1 de 2 LG Optimus V Speaker Replacement: paso 8, imagen 2 de 2
    • To fix the speaker, use a soldering iron to heat up the two areas where the wires connect to the motherboard. Then, remove the old speaker and replace it with a new one by soldering it back onto the same areas.
    • Once you’re done, your speaker should be working properly again.
Conclusión
Una persona más ha completado esta guía.
Equipo
UMass Dartmouth, Team 1-2, Shastany Fall 2013 Miembro de UMass Dartmouth, Team 1-2, Shastany Fall 2013
UMASSD-SHASTANY-F13S1G2
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 7
Todo El Tiempo: 784
