Saltar al contenido principal
LG Optimus V Screen Replacement
Qué necesitas
  1. LG Optimus V Screen Replacement, Battery: paso 1, imagen 1 de 1
    • Turn the LG Optimus V over, so that the back cover is facing upward.
  2. LG Optimus V Screen Replacement: paso 2, imagen 1 de 1
    • Locate the opening above the camera.
    • Use a spudger to detach the back cover.
  3. LG Optimus V Screen Replacement: paso 3, imagen 1 de 3 LG Optimus V Screen Replacement: paso 3, imagen 2 de 3 LG Optimus V Screen Replacement: paso 3, imagen 3 de 3
    • Gently remove the battery with your spudger.
  4. LG Optimus V Screen Replacement, Camera: paso 4, imagen 1 de 2 LG Optimus V Screen Replacement, Camera: paso 4, imagen 2 de 2
    • Remove the six screws on the silver casing.
    • Use the plastic opening tool to remove the silver casing.
  5. LG Optimus V Screen Replacement: paso 5, imagen 1 de 3 LG Optimus V Screen Replacement: paso 5, imagen 2 de 3 LG Optimus V Screen Replacement: paso 5, imagen 3 de 3
    • Use a plastic opening tool to remove each area holding the parts together.
  6. LG Optimus V Screen Replacement: paso 6, imagen 1 de 2 LG Optimus V Screen Replacement: paso 6, imagen 2 de 2
    • Use a plastic opening tool to remove the small black and yellow piece that reads Y3114C.
    • Use a plastic opening tool to pry off the camera.
  7. LG Optimus V Screen Replacement, Screen: paso 7, imagen 1 de 1
    • Once you have removed the antenna, unscrew the two screws located on the sides of the charging port.
  8. LG Optimus V Screen Replacement: paso 8, imagen 1 de 2 LG Optimus V Screen Replacement: paso 8, imagen 2 de 2
    • Using your plastic opening tool, lift up the connectors on either side of the motherboard.
  9. LG Optimus V Screen Replacement: paso 9, imagen 1 de 1
    • Remove the motherboard and set it aside.
  10. LG Optimus V Screen Replacement: paso 10, imagen 1 de 1
    • Using a plastic opening tool, detach the screen from the plastic casing of the phone.
Conclusión
3 personas más completaron esta guía.
Equipo
UMass Dartmouth, Team 1-2, Shastany Fall 2013 Miembro de UMass Dartmouth, Team 1-2, Shastany Fall 2013
UMASSD-SHASTANY-F13S1G2
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 5
Todo El Tiempo: 2,562
