Saltar al contenido principal
LG Optimus T Motherboard Replacement
Qué necesitas
  1. LG Optimus T Motherboard Replacement, Motherboard: paso 1, imagen 1 de 3 LG Optimus T Motherboard Replacement, Motherboard: paso 1, imagen 2 de 3 LG Optimus T Motherboard Replacement, Motherboard: paso 1, imagen 3 de 3
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Using a prying device, such as a plastic opening tool, remove the phone’s back cover. At the top of the phone, there’s an indentation to put the Spudger into to pop the case off
  2. LG Optimus T Motherboard Replacement: paso 2, imagen 1 de 1
    • Remove the battery. There’s an indentation to the left of the camera lens to pull up on the battery with your finger
  3. LG Optimus T Motherboard Replacement: paso 3, imagen 1 de 1
    • Use a J0 screwdriver to remove the six 4.5mm screws.
  4. LG Optimus T Motherboard Replacement: paso 4, imagen 1 de 2 LG Optimus T Motherboard Replacement: paso 4, imagen 2 de 2
    • You might have difficulty popping the interior case off. You may use the metal spudger here with caution if the plastic opening tool fails
    • Remove interior case. Insert the spudger into the indentations at the top, or bottom of the phone to pry off the interior case.
  5. LG Optimus T Motherboard Replacement: paso 5, imagen 1 de 1
    • Pull up on connector tab
  6. LG Optimus T Motherboard Replacement: paso 6, imagen 1 de 2 LG Optimus T Motherboard Replacement: paso 6, imagen 2 de 2
    • Remove SD card mount. Insert the plastic opening tool on the right side to pop off
  7. LG Optimus T Motherboard Replacement: paso 7, imagen 1 de 2 LG Optimus T Motherboard Replacement: paso 7, imagen 2 de 2
    • Remove metal panel
    • There are four retaining points to insert plastic opening tool and pop off panel
  8. LG Optimus T Motherboard Replacement: paso 8, imagen 1 de 1
    • Use a J0 screwdriver to remove the two 1.8mm screws from charging port. (Charging port and motherboard are connected.)
    • Remove motherboard
Conclusión
Una persona más ha completado esta guía.
stacey
Miembro Desde 02/07/17
219 Reputación
2 Guías creadas
Equipo
Ohio State, Team 1-3, Wilder Spring 2017 Miembro de Ohio State, Team 1-3, Wilder Spring 2017
OSU-WILDER-S17S1G3
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 10
Todo El Tiempo: 308
