Saltar al contenido principal
LG Optimus T Camera and Camera Mount Replacement
Qué necesitas
  1. LG Optimus T Camera and Camera Mount Replacement, Camera: paso 1, imagen 1 de 2 LG Optimus T Camera and Camera Mount Replacement, Camera: paso 1, imagen 2 de 2
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down your device before you begin.
    • Use a plastic opening tool to remove the phone's back cover. At the top of the phone there are indentations to insert the spudger and pop the case off
  2. LG Optimus T Camera and Camera Mount Replacement: paso 2, imagen 1 de 1
    • Remove the battery by pulling up on the battery using the indentation to the left of the camera lens
  3. LG Optimus T Camera and Camera Mount Replacement: paso 3, imagen 1 de 1
    • Use a J0 screwdriver to remove the 6 highlighted screws
  4. LG Optimus T Camera and Camera Mount Replacement: paso 4, imagen 1 de 2 LG Optimus T Camera and Camera Mount Replacement: paso 4, imagen 2 de 2
    • Remove interior case using indentations on the top and bottom to insert the spudger to pop off the interior case
    • You might have difficulty popping the interior case off. You may use the metal spudger here with caution if the plastic one fails
  5. LG Optimus T Camera and Camera Mount Replacement: paso 5, imagen 1 de 1
    • Unhook the connector tab
  6. LG Optimus T Camera and Camera Mount Replacement: paso 6, imagen 1 de 1
    • Remove SD card mount by inserting the plastic opening tool on the right side of the device to pop mount off
  7. LG Optimus T Camera and Camera Mount Replacement: paso 7, imagen 1 de 2 LG Optimus T Camera and Camera Mount Replacement: paso 7, imagen 2 de 2
    • Remove metal panel by inserting plastic opening tool into the four retaining points and remove panel
  8. LG Optimus T Camera and Camera Mount Replacement: paso 8, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • disconnect camera connector from motherboard by spudger
    • Once disconnected, remove camera using tweezers
Conclusión
stacey
Miembro Desde 02/07/17
219 Reputación
2 Guías creadas
Equipo
Ohio State, Team 1-3, Wilder Spring 2017 Miembro de Ohio State, Team 1-3, Wilder Spring 2017
OSU-WILDER-S17S1G3
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 9
Todo El Tiempo: 121
