Saltar al contenido principal
LG Optimus L9 P769 Micro-USB Port Replacement
Qué necesitas
  1. LG Optimus L9 P769 Micro-USB Port Replacement, Micro-USB Port: paso 1, imagen 1 de 1
    • Power off the device and gently lift the battery cover off to access the battery
  2. LG Optimus L9 P769 Micro-USB Port Replacement: paso 2, imagen 1 de 1
    • Lift and remove the battery from the notch in the edge of the battery compartment
  3. LG Optimus L9 P769 Micro-USB Port Replacement: paso 3, imagen 1 de 2 LG Optimus L9 P769 Micro-USB Port Replacement: paso 3, imagen 2 de 2
    • Remove all 10 of the 4.5mm screws that hold the back frame to the case of the phone using a PH000 screwdriver.
  4. LG Optimus L9 P769 Micro-USB Port Replacement: paso 4, imagen 1 de 2 LG Optimus L9 P769 Micro-USB Port Replacement: paso 4, imagen 2 de 2
    • Using a small prying tool, carefully remove the back frame by prying on the sides of the device.
    • Do be careful when prying back frame and removing it as too much force may result in damaging the frame.
  5. LG Optimus L9 P769 Micro-USB Port Replacement: paso 5, imagen 1 de 3 LG Optimus L9 P769 Micro-USB Port Replacement: paso 5, imagen 2 de 3 LG Optimus L9 P769 Micro-USB Port Replacement: paso 5, imagen 3 de 3
    • Remove both connections of the antenna by pulling up with tweezers
  6. LG Optimus L9 P769 Micro-USB Port Replacement: paso 6, imagen 1 de 3 LG Optimus L9 P769 Micro-USB Port Replacement: paso 6, imagen 2 de 3 LG Optimus L9 P769 Micro-USB Port Replacement: paso 6, imagen 3 de 3
    • Remove Micro-USB Cache by unscrewing both 2.9mm screws with the PH000 headtype
  7. LG Optimus L9 P769 Micro-USB Port Replacement: paso 7, imagen 1 de 1
    • Detach module from motherboard using a prying tool
  8. LG Optimus L9 P769 Micro-USB Port Replacement: paso 8, imagen 1 de 2 LG Optimus L9 P769 Micro-USB Port Replacement: paso 8, imagen 2 de 2
    • Remove 1.8mm screw to free Micro-USB module for removal using the PH000 headtype
  9. LG Optimus L9 P769 Micro-USB Port Replacement: paso 9, imagen 1 de 2 LG Optimus L9 P769 Micro-USB Port Replacement: paso 9, imagen 2 de 2
    • Use a small prying tool to detach the Micro-USB circuitry from the case of the phone
  10. LG Optimus L9 P769 Micro-USB Port Replacement: paso 10, imagen 1 de 1
    • Comparison showing the Micro-USB module against the empty phone casing
Conclusión
Kayden G
Miembro Desde 03/01/17
272 Reputación
2 Guías creadas
Equipo
IUPUI, Team S2-G1, Harley Spring 2017 Miembro de IUPUI, Team S2-G1, Harley Spring 2017
IUPUI-HARLEY-S17S2G1
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 319
