Saltar al contenido principal
LG Optimus L7 P705 Display Replacement
Qué necesitas
  1. LG Optimus L7 P705 Display Replacement, Display: paso 1, imagen 1 de 2 LG Optimus L7 P705 Display Replacement, Display: paso 1, imagen 2 de 2
    • Insert a plastic opening tool between the seams of the device and pry the back cover away from the phone.
    • Remove the battery and simcard.
  2. LG Optimus L7 P705 Display Replacement: paso 2, imagen 1 de 1
    • Remove twelve 3mm screws (with the phillips head 000) around frame and near sim and sd cards.
  3. LG Optimus L7 P705 Display Replacement: paso 3, imagen 1 de 1
    • Remove bottom plate where the charger port is located.
  4. LG Optimus L7 P705 Display Replacement: paso 4, imagen 1 de 2 LG Optimus L7 P705 Display Replacement: paso 4, imagen 2 de 2
    • Insert a plastic opening tool between the seams of the device and apply some pressure to lift off the cover.
  5. LG Optimus L7 P705 Display Replacement: paso 5, imagen 1 de 2 LG Optimus L7 P705 Display Replacement: paso 5, imagen 2 de 2
    • Flip over to the face of the device.
    • Lift off glass screen (display).
Conclusión
8 personas más completaron esta guía.
Craig Lashley
Miembro Desde 10/08/14
307 Reputación
1 Guía escrita
Equipo
USF Tampa, Team 9-1, Leahy Fall 2014 Miembro de USF Tampa, Team 9-1, Leahy Fall 2014
USFT-LEAHY-F14S9G1
3 Miembros
5 Guías creadas
2 comentarios
Great tutorial as always on ifixit. Just be mindful of the top clip holding the glass bevel as it can be tricky and is close to circuitry.
Sooty - Contestar
Im miles i great this ifixit i'm beginner
Omair Sarip -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 2
Ultimos 30 días: 13
Todo El Tiempo: 5,406
