Saltar al contenido principal
LG Optimus G Pro SIM/MicroSD Assembly Replacement
Qué necesitas
  1. LG Optimus G Pro SIM/MicroSD Assembly Replacement, Remove Back Cover.: paso 1, imagen 1 de 1
    • Make sure before you begin working on your device, that the device is not charging.
    • Once you have access to the phone, there is a small indent on the bottom left side. Use your fingernail or a plastic opening tool to pry from here and pull off the back casing.
  2. LG Optimus G Pro SIM/MicroSD Assembly Replacement, Remove the Battery.: paso 2, imagen 1 de 1
    • Once you have properly removed the outer casing, the back should look as so.
    • To remove the battery, pull up from the red mark using your finger. The battery should come up at an angle, and easily be able to be removed.
    • Once the battery is removed you may safely proceed to the next step.
  3. LG Optimus G Pro SIM/MicroSD Assembly Replacement, Screw Removal: paso 3, imagen 1 de 2 LG Optimus G Pro SIM/MicroSD Assembly Replacement, Screw Removal: paso 3, imagen 2 de 2
    • Make sure you remove the battery first. You will see that there are 14 screws on the back of the inner case. Use the Phillips head screwdriver to remove each of the screws, make sure to put the screws in a safe place where they will not get lost.
  4. LG Optimus G Pro SIM/MicroSD Assembly Replacement, Remove Cover: paso 4, imagen 1 de 1
    • Once you have removed all the screws, you can begin removing the inside cover.
    • Insert the opening tool using a sliding motion into one of the corners and move it along the edges of the inside cover. This will loosen the edges and the inside cover will pry apart from the shell.
  5. LG Optimus G Pro SIM/MicroSD Assembly Replacement, Completion: paso 5, imagen 1 de 1
    • The inner cover is now removed, you now have access to the many parts on the inside of the phone.
  6. LG Optimus G Pro SIM/MicroSD Assembly Replacement, Remove the Ribbon Cable: paso 6, imagen 1 de 1
    • Using your plastic opening tool, disconnect the connection between the phone and the ribbon cable. Make sure to use even pressure as you apply it to the cable.
  7. LG Optimus G Pro SIM/MicroSD Assembly Replacement, Remove the Sisterboard.: paso 7, imagen 1 de 2 LG Optimus G Pro SIM/MicroSD Assembly Replacement, Remove the Sisterboard.: paso 7, imagen 2 de 2
    • In this next step it is easy to pry the wrong piece. Make sure to pry at the metal platform that the sister board sits on, not the orange printed circuit board itself.
    • Using your prying tool, pry at the right red marked corner, making sure to pull at the metal platform under the circuit board. Once it is raised slightly, pull along the underside until the left red mark. This should loosen the board and allow it to be removed.
    • If it's still unable to be removed, try to pry at the orange mark, making sure to pull at the same metal platform.
  8. LG Optimus G Pro SIM/MicroSD Assembly Replacement, Completed.: paso 8, imagen 1 de 1
    • You can now raise and remove the sisterboard with your plastic opening tool or your fingers.
Conclusión
6 personas más completaron esta guía.
Wesley Pate
Miembro Desde 09/25/14
1,641 Reputación
7 Guías creadas
Equipo
USF Tampa, Team 15-5, Remmell Fall 2014 Miembro de USF Tampa, Team 15-5, Remmell Fall 2014
USFT-REMMELL-F14S15G5
Miembros de 3
7 Guías creadas
5Guía Comentarios
Can this part use to replace LG Gx F310L (LG Optimus G Pro Korean version)?
zlebors - Contestar
Oops! The tutorial makes no mention of the 3 little buttons that will fall out when taking off the inner cover. I'm using tape from the outside to hold the buttons in place.
Robert Cartier - Contestar
Really nice instructions, thanks. One point of confusion for me, the original metal platform had raised edges and the one on the replacement did not. Just an FYI for others that may be momentarily stumped like I was.
tleidig - Contestar
How can I get the sim panel? Pls I need it
Bamidele - Contestar
My Sim Jecket is troubling. I want new sim circuit.
Hamza Shah - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 25
Todo El Tiempo: 3,564
