Saltar al contenido principal
LG Optimus G Battery Replacement
Qué necesitas
  1. LG Optimus G Battery Replacement, Remove the simcard: paso 1, imagen 1 de 2 LG Optimus G Battery Replacement, Remove the simcard: paso 1, imagen 2 de 2
    • SIM eject tool
  2. LG Optimus G Battery Replacement, Remove the back cover: paso 2, imagen 1 de 2 LG Optimus G Battery Replacement, Remove the back cover: paso 2, imagen 2 de 2
    • Remove the 2 screws holding the back cover using a T5 screwdriver.
    • Use a guitar pick or a plastic opening tool to free the clips on the top and each side of the back cover.
    • Use an opening pick to pry off the rear case.
  3. LG Optimus G Battery Replacement, Removing the battery: paso 4, imagen 1 de 2 LG Optimus G Battery Replacement, Removing the battery: paso 4, imagen 2 de 2
    • Remove the tape over the battery, the screws and the antenna connector cord.
    • Be careful removing the golden tape because it is below the antenna connector cord.
  4. LG Optimus G Battery Replacement: paso 5, imagen 1 de 2 LG Optimus G Battery Replacement: paso 5, imagen 2 de 2
    • Remove the the screws securing the battery cable connector.
    • Disconnect the battery cable.
  5. LG Optimus G Battery Replacement: paso 6, imagen 1 de 1
    • The battery is held down by some adhesive.
    • Carefully heat the battery to loosen the adhesive holding it to the case.
  6. LG Optimus G Battery Replacement: paso 7, imagen 1 de 2 LG Optimus G Battery Replacement: paso 7, imagen 2 de 2
    • Pry the battery up from the case.
    • Be very careful not to puncture the battery when prying. Use blunt plastic tools.
  7. LG Optimus G Battery Replacement: paso 8, imagen 1 de 3 LG Optimus G Battery Replacement: paso 8, imagen 2 de 3 LG Optimus G Battery Replacement: paso 8, imagen 3 de 3
    • The battery is removed.
    • Replace the battery with a new one.
Conclusión
7 personas más completaron esta guía.
Eneider Colina
Miembro Desde 09/20/13
2,362 Reputación
9 Guías creadas
Equipo
5 comentarios
“Heat gun”is too vague. So is IR thermometer. What temperature to soften adhesive? How would I know if I was buying the right things?
Deep - Contestar
I’m not using a heat gun, it´s a hairdryer; on this case the hairdryer hardly exceeds the 60°C and that is enough to remove the battery. If you want to buy a heat gun you must be careful not to use more than 50 °
Eneider Colina - Contestar
Where do you suggest ordering a replacement battery from?
snack le - Contestar
you can search it on Amazon and buy directly from LG.
Eneider Colina -
Thank you so much for this wonderful article it helped me replace my battery. I bought my replacement battery from here:-
https://www.phonepartworld.com/LG/LG-Opt...
ricksanchez - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 13
Todo El Tiempo: 5,126
