Introducción
You may need to replace your speaker if you notice a decrease in sound quality while using your phone or while listening to music.
Qué necesitas
Use the opening on the right side of the phone to pull off the plastic back cover.
Remove the six 1.4mm screws using a Phillips head screwdriver with a size PH00 bit. Then fully remove the back panel with a plastic opening tool.
Casi Terminas!
Conclusión
