Saltar al contenido principal
LG Optimus Fuel Speaker Replacement
Qué necesitas
  1. LG Optimus Fuel Speaker Replacement, Battery: paso 1, imagen 1 de 2 LG Optimus Fuel Speaker Replacement, Battery: paso 1, imagen 2 de 2
    • Use the opening on the right side of the phone to pull off the plastic back cover.
  2. LG Optimus Fuel Speaker Replacement: paso 2, imagen 1 de 3 LG Optimus Fuel Speaker Replacement: paso 2, imagen 2 de 3 LG Optimus Fuel Speaker Replacement: paso 2, imagen 3 de 3
    • Use the curved opening at the center-bottom of the battery to carefully remove the old battery.
  3. LG Optimus Fuel Speaker Replacement, Speaker: paso 3, imagen 1 de 3 LG Optimus Fuel Speaker Replacement, Speaker: paso 3, imagen 2 de 3 LG Optimus Fuel Speaker Replacement, Speaker: paso 3, imagen 3 de 3
    • Remove the six 1.4mm screws using a Phillips head screwdriver with a size PH00 bit. Then fully remove the back panel with a plastic opening tool.
  4. LG Optimus Fuel Speaker Replacement: paso 4, imagen 1 de 3 LG Optimus Fuel Speaker Replacement: paso 4, imagen 2 de 3 LG Optimus Fuel Speaker Replacement: paso 4, imagen 3 de 3
    • Remove the speaker from the back panel. You may have to use some tweezers if you are having a hard time grabbing the speaker with your fingers.
    • Remember to take note of where the two springs on the speaker are positioned before removing it. Install the new speaker with the springs in this same position.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 239
