Saltar al contenido principal
LG Optimus F60 Speaker Replacement
Qué necesitas
  1. LG Optimus F60 Speaker Replacement, Battery: paso 1, imagen 1 de 3 LG Optimus F60 Speaker Replacement, Battery: paso 1, imagen 2 de 3 LG Optimus F60 Speaker Replacement, Battery: paso 1, imagen 3 de 3
    • Hold the phone in your hand and position the small plastic opening tool or your finger under the lip of the phone by the USB port.
    • Pry or lift up on the indent with the opening tool.
    • Remove the back panel.
  2. LG Optimus F60 Speaker Replacement: paso 2, imagen 1 de 3 LG Optimus F60 Speaker Replacement: paso 2, imagen 2 de 3 LG Optimus F60 Speaker Replacement: paso 2, imagen 3 de 3
    • Place the small plastic opening tool or your finger at the indentation at the base of the battery.
    • Pry upwards or lift with your finger and remove battery.
  3. LG Optimus F60 Speaker Replacement, Speaker: paso 3, imagen 1 de 3 LG Optimus F60 Speaker Replacement, Speaker: paso 3, imagen 2 de 3 LG Optimus F60 Speaker Replacement, Speaker: paso 3, imagen 3 de 3
    • Use the Phillips #000 screwdriver to remove eight screws.
  4. LG Optimus F60 Speaker Replacement: paso 4, imagen 1 de 2 LG Optimus F60 Speaker Replacement: paso 4, imagen 2 de 2
    • Insert the iFixit opening tool in the indentation.
    • Pry the plastic using the opening tool to remove the lower back panel.
    • Remove the back panel from the device.
  5. LG Optimus F60 Speaker Replacement: paso 5, imagen 1 de 3 LG Optimus F60 Speaker Replacement: paso 5, imagen 2 de 3 LG Optimus F60 Speaker Replacement: paso 5, imagen 3 de 3
    • Start at the changing port, and continue to pry at the edges until loose enough to remove.
  6. LG Optimus F60 Speaker Replacement: paso 6, imagen 1 de 3 LG Optimus F60 Speaker Replacement: paso 6, imagen 2 de 3 LG Optimus F60 Speaker Replacement: paso 6, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Gently pry the foam seal from around the speaker.
    • Pry out speaker using tweezers.
    • Remove and replace the speaker.
Conclusión
3 personas más completaron esta guía.
Equipo
IUPUI, Team S2-G5, Henning Spring 2019 Miembro de IUPUI, Team S2-G5, Henning Spring 2019
IUPUI-HENNING-S19S2G5
3 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 8
Todo El Tiempo: 97
