Introducción
This guide will take you through the process of replacing the power button in an LG Optimus F60. This task should take about 2-4 minutes to complete.
Qué necesitas
Hold the phone in your hand and position the small plastic opening tool or your finger under the lip of the phone by the USB port.
Pry or lift up on the indent with the opening tool.
Remove the back panel.
Remove the eight 4 mm screws on the inner panel using the phillips #000 Screwdriver
