Saltar al contenido principal
LG Optimus F60 Front Camera Replacement
Qué necesitas
  1. LG Optimus F60 Front Camera Replacement, Battery: paso 1, imagen 1 de 3 LG Optimus F60 Front Camera Replacement, Battery: paso 1, imagen 2 de 3 LG Optimus F60 Front Camera Replacement, Battery: paso 1, imagen 3 de 3
    • Hold the phone in your hand and position the small plastic opening tool or your finger under the lip of the phone by the USB port.
    • Pry or lift up on the indent with the opening tool.
    • Remove the back panel.
  2. LG Optimus F60 Front Camera Replacement: paso 2, imagen 1 de 3 LG Optimus F60 Front Camera Replacement: paso 2, imagen 2 de 3 LG Optimus F60 Front Camera Replacement: paso 2, imagen 3 de 3
    • Place the small plastic opening tool or your finger at the indentation at the base of the battery.
    • Pry upwards or lift with your finger and remove battery.
  3. LG Optimus F60 Front Camera Replacement, Front Camera: paso 3, imagen 1 de 2 LG Optimus F60 Front Camera Replacement, Front Camera: paso 3, imagen 2 de 2
    • Use the phillips #000 Screwdriver to unscrew eight 4mm screws.
  4. LG Optimus F60 Front Camera Replacement: paso 4, imagen 1 de 2 LG Optimus F60 Front Camera Replacement: paso 4, imagen 2 de 2
    • Insert the plastic opening tool in the indentation marked by the red square.
    • Pry the plastic opening tool upwards to release the lower back panel.
    • Remove the lower back panel from the device.
  5. LG Optimus F60 Front Camera Replacement: paso 5, imagen 1 de 3 LG Optimus F60 Front Camera Replacement: paso 5, imagen 2 de 3 LG Optimus F60 Front Camera Replacement: paso 5, imagen 3 de 3
    • Continue moving plastic opening tool around device until back panel is loose enough to remove.
  6. LG Optimus F60 Front Camera Replacement: paso 6, imagen 1 de 3 LG Optimus F60 Front Camera Replacement: paso 6, imagen 2 de 3 LG Optimus F60 Front Camera Replacement: paso 6, imagen 3 de 3
    • Locate the digitizer connection on the lower left hand side of the device.
    • Use the tweezers to lift up and gently remove the connector.
  7. LG Optimus F60 Front Camera Replacement: paso 7, imagen 1 de 3 LG Optimus F60 Front Camera Replacement: paso 7, imagen 2 de 3 LG Optimus F60 Front Camera Replacement: paso 7, imagen 3 de 3
    • Locate the front camera on the upper left hand side of the device. The camera is marked in red.
    • Use the tweezers to remove the front camera from the connector marked in orange.
    • Remove and replace front camera.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 8
Todo El Tiempo: 210
