Saltar al contenido principal
LG Optimus F3 Headphone Jack Replacement
Qué necesitas
  1. LG Optimus F3 Headphone Jack Replacement, Headphone Jack: paso 1, imagen 1 de 1
    • Place your thumb at the bottom of the phone's back where the charging port is located.
    • Gently pull the cover off.
  2. LG Optimus F3 Headphone Jack Replacement: paso 2, imagen 1 de 1
    • Using the indent at the bottom of the battery, lift and remove the battery from the phone.
    • Place the battery in a safe location as you will need it for reassembly.
  3. LG Optimus F3 Headphone Jack Replacement: paso 3, imagen 1 de 1
    • Remove the ten 1.0 mm screws on the rear case.
    • Place the screws in a safe location as you will need them for reassembly.
  4. LG Optimus F3 Headphone Jack Replacement: paso 4, imagen 1 de 1
    • Pry apart the joints to separate the inner case.
    • Insert the opening tool on different locations until the case comes off easily.
    • To avoid damaging the joints of the case do not pry if there is resistance.
  5. LG Optimus F3 Headphone Jack Replacement: paso 5, imagen 1 de 1
    • With the inner cover removed, locate your headphone jack.
    • It will be in the upper right corner on the back of the phone.
  6. LG Optimus F3 Headphone Jack Replacement: paso 6, imagen 1 de 1
    Herramienta utilizada en este paso:
    • Gently grab the headphone jack along the sides with tweezers.
    • Lift the headphone jack out of its socket.
  7. LG Optimus F3 Headphone Jack Replacement: paso 7, imagen 1 de 1
    • Insert the new headphone jack into the headphone socket by lining up the connectors and gently pressing down.
    • Make sure the dark side without the connectors is face up.
Conclusión
To reassemble your device follow these steps in reverse order.
4 personas más completaron esta guía.
Ryan McDermott
Miembro Desde 10/28/15
324 Reputación
2 Guías creadas
Equipo
UMass Dartmouth, Team 1-5, Miles Fall 2015 Miembro de UMass Dartmouth, Team 1-5, Miles Fall 2015
UMASSD-MILES-F15S1G5
Miembros de 3
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 26
Todo El Tiempo: 581
