Saltar al contenido principal
LG Optimus F3 Charging port unit Replacement
Qué necesitas
  1. LG Optimus F3 Charging port unit  Replacement, Motherboard: paso 1, imagen 1 de 1
    • Turn the device so that the back faces up.
    • It is easiest to open the case near the charging port located at the bottom of the phone.
    • Remove the back case by pushing up on the back and pulling down on the face as illustrated in the image.
  2. LG Optimus F3 Charging port unit  Replacement: paso 2, imagen 1 de 1
    • With back case removed, the battery is visible. The battery is the large square object.
    • Remove the battery by flipping the bottom edge upward to separate the battery from the case.
  3. LG Optimus F3 Charging port unit  Replacement: paso 3, imagen 1 de 1
    • Remove 10 1.0 mm screws located on the back of the device.
    • Refer to the outlined locations in the image for the screws.
  4. LG Optimus F3 Charging port unit  Replacement: paso 4, imagen 1 de 1
    • Use the plastic opening tool to separate the inner case from the device.
    • Wedge the plastic opening tool between the case.
    • Wiggle the tool and use leverage to pry the case apart.
  5. LG Optimus F3 Charging port unit  Replacement: paso 5, imagen 1 de 1
    • The camera unit is located at the top left of the phone. The camera is a silver box with a black lens. The image pin points where the camera is on the motherboard.
    • Use the plastic opening tool to separate the camera from the motherboard.
    • Wedge the plastic tool between the camera and the motherboard to loosen the camera unit.
  6. LG Optimus F3 Charging port unit  Replacement: paso 6, imagen 1 de 1
    Herramienta utilizada en este paso:
    • Use a pair of tweezers to disconnect and remove the rear facing camera.
  7. LG Optimus F3 Charging port unit  Replacement: paso 7, imagen 1 de 1
    • Use the plastic opening tool to separate the sim card and the memory card connector from the motherboard.
    • Note that the sim card and the memory card connector are one unit.
    • Wedge the plastic tool to lift up the sim-memory unit from the motherboard.
  8. LG Optimus F3 Charging port unit  Replacement: paso 8, imagen 1 de 1
    • Use the plastic opening tool to remove the charging port unit.
    • Wedge the plastic opening tool between the charging port unit and the motherboard to separate the port.
  9. LG Optimus F3 Charging port unit  Replacement: paso 9, imagen 1 de 1
    • Use the plastic opening tool to remove the motherboard located directly above the battery encasement.
    • The motherboard is an L-shaped unit above and to the left of the battery encasement.
    • Wedge the plastic opening tool between the circuit board and the motherboard to separate the unit.
  10. LG Optimus F3 Charging port unit  Replacement, Charging port unit: paso 10, imagen 1 de 1
    • Remove one 1.0 mm screw.
  11. LG Optimus F3 Charging port unit  Replacement: paso 11, imagen 1 de 1
    • Use a plastic opening tool to remove front glass protector.
  12. LG Optimus F3 Charging port unit  Replacement: paso 12, imagen 1 de 1
    • Use the plastic opening tool to remove front glass cover carefully. Try not to break the connector.
  13. LG Optimus F3 Charging port unit  Replacement: paso 13, imagen 1 de 1
    • Remove the front facing camera.
  14. LG Optimus F3 Charging port unit  Replacement: paso 14, imagen 1 de 1
    • Use the plastic opening tool to carefully remove the home button board. It is attached with double-sided tape.
  15. LG Optimus F3 Charging port unit  Replacement: paso 15, imagen 1 de 1
  16. LG Optimus F3 Charging port unit  Replacement: paso 16, imagen 1 de 1
    • You are all set.
Conclusión
3 personas más completaron esta guía.
Jonathan Fang
Miembro Desde 10/28/15
356 Reputación
2 Guías creadas
Equipo
UMass Dartmouth, Team 1-5, Miles Fall 2015 Miembro de UMass Dartmouth, Team 1-5, Miles Fall 2015
UMASSD-MILES-F15S1G5
Miembros de 3
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 5
Ultimos 30 días: 33
Todo El Tiempo: 647
