Saltar al contenido principal
LG Optimus F3 Battery Replacement
  1. LG Optimus F3 Battery Replacement, Ensuring power is off.: paso 1, imagen 1 de 1
    • Make sure the power is turned off.
  2. LG Optimus F3 Battery Replacement, Remove the back cover: paso 2, imagen 1 de 1
    • Hold the phone with both hands and use the fingertip cutout located on top of the cover to pull it open and remove it.
  3. LG Optimus F3 Battery Replacement, Remove old battery.: paso 3, imagen 1 de 1
    • Lift the battery using the fingertip cutout located at the top of the battery compartment and remove it from the device.
  4. LG Optimus F3 Battery Replacement, Insert new battery.: paso 4, imagen 1 de 1
    • Remove the new battery from its packaging. Insert the battery into the opening in the back of the device, making sure the connectors align.
Conclusión
Una persona más ha completado esta guía.
Mohammd Younis
Miembro Desde 10/07/14
122 Reputación
1 Guía escrita
Equipo
USF Tampa, Team 7-3, Leahy Fall 2014 Miembro de USF Tampa, Team 7-3, Leahy Fall 2014
USFT-LEAHY-F14S7G3
Miembros de 4
5 Guías creadas
0 Guide Comments
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 417
