Saltar al contenido principal
LG Notebook LGC40 A410 WiFi module Replacement
Qué necesitas
  1. LG Notebook LGC40 A410 WiFi module Replacement, Locate the keys to unlock and release the battery: paso 1, imagen 1 de 1
    • Put the notebook upside down, preferably on top of a soft surface so any movement doesn't scratch the top cover.
    • Locate the keys to unlock and release the battery
  2. LG Notebook LGC40 A410 WiFi module Replacement, Unlock the battery: paso 2, imagen 1 de 1
    • Slide the unlock key in the indicated direction to unlock the battery
  3. LG Notebook LGC40 A410 WiFi module Replacement, Release and remove the battery: paso 3, imagen 1 de 2 LG Notebook LGC40 A410 WiFi module Replacement, Release and remove the battery: paso 3, imagen 2 de 2
    • Slide and hold the release key in the indicated direction
    • Pull out the battery
  4. LG Notebook LGC40 A410 WiFi module Replacement, Remove the WiFi module cover: paso 4, imagen 1 de 1
    • With the notebook upside down, locate the WiFi module cover and unscrew the philips screw.
  5. LG Notebook LGC40 A410 WiFi module Replacement, Remove the antenna connectors: paso 5, imagen 1 de 2 LG Notebook LGC40 A410 WiFi module Replacement, Remove the antenna connectors: paso 5, imagen 2 de 2
    • Locate the antenna connectors on the WiFi module
    • Holding the antenna connectors with the tips of your fingers, carefully pull them out of the WiFi module board.
  6. LG Notebook LGC40 A410 WiFi module Replacement, Remove the WiFi module: paso 6, imagen 1 de 1
    • Remove the philips screw
    • Lift the WiFi module by the edge where the screw is located
    • Pull the WiFi module from the motherboard connector
Conclusión
Una persona más ha completado esta guía.
Claudio Felix
Miembro Desde 01/01/16
863 Reputación
7 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 11
Todo El Tiempo: 1,348
