Qué necesitas
With one hand, push the rectangular button located on the back top-side of the phone.
The last piece of tape is the gold piece located near the middle of the phone on the back of the silver LCD and across the copper colored ribbon. Carefully peel off the tape without ripping or damaging the copper ribbon.
Hold the ribbon down with 2 fingers, one on each side of the tape, and peel the tape off with the other hand.
Once it has been lifted up slightly you will be able to slide the bottom half of the green circuit board located below the screen off of the phone by pulling down on it. Then you will be able to finish popping the screen out.
Get a new screen and replace it. Follow the instructions in reverse to reassemble the phone with your new screen.
