Saltar al contenido principal
LG Muziq LX570 Motherboard Replacement
Qué necesitas
  1. LG Muziq LX570 Motherboard Replacement, Battery: paso 1, imagen 1 de 2 LG Muziq LX570 Motherboard Replacement, Battery: paso 1, imagen 2 de 2
    • Slide the battery cover release towards top of phone.
    • Place one finger at each side of the battery cover.
    • Lift and remove the battery cover.
  2. LG Muziq LX570 Motherboard Replacement: paso 2, imagen 1 de 2 LG Muziq LX570 Motherboard Replacement: paso 2, imagen 2 de 2
    • Place a finger at the top corner of the battery and lift out of the phone.
  3. LG Muziq LX570 Motherboard Replacement, Rear Case: paso 3, imagen 1 de 2 LG Muziq LX570 Motherboard Replacement, Rear Case: paso 3, imagen 2 de 2
    • Use the spudger to lift up the two screw covers at the top of the phone.
    • Remove all four Phillips#00 (3.3mm) screws with screwdriver.
  4. LG Muziq LX570 Motherboard Replacement: paso 4, imagen 1 de 3 LG Muziq LX570 Motherboard Replacement: paso 4, imagen 2 de 3 LG Muziq LX570 Motherboard Replacement: paso 4, imagen 3 de 3
    • Use the spudger to lift up the rear case from the phone.
    • Note: Rear case is connected on all sides and will have to be detached on all sides before removal.
    • Remove the rear case from the device.
  5. LG Muziq LX570 Motherboard Replacement, Motherboard: paso 5, imagen 1 de 3 LG Muziq LX570 Motherboard Replacement, Motherboard: paso 5, imagen 2 de 3 LG Muziq LX570 Motherboard Replacement, Motherboard: paso 5, imagen 3 de 3
    • Use the spudger to lift the motherboard from the phone.
Conclusión
Braden Burk
Miembro Desde 01/22/12
1 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 3-29, Amido Winter 2012 Miembro de Cal Poly, Team 3-29, Amido Winter 2012
CPSU-AMIDO-W12S3G29
4 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 5
Ultimos 30 días: 10
Todo El Tiempo: 765
