Saltar al contenido principal
LG Muziq LX570 Keypad Replacement
Qué necesitas
  1. LG Muziq LX570 Keypad Replacement, Battery: paso 1, imagen 1 de 2 LG Muziq LX570 Keypad Replacement, Battery: paso 1, imagen 2 de 2
    • Slide the battery cover release towards top of phone.
    • Place one finger at each side of the battery cover.
    • Lift and remove the battery cover.
  2. LG Muziq LX570 Keypad Replacement: paso 2, imagen 1 de 2 LG Muziq LX570 Keypad Replacement: paso 2, imagen 2 de 2
    • Place a finger at the top corner of the battery and lift out of the phone.
  3. LG Muziq LX570 Keypad Replacement, Rear Case: paso 3, imagen 1 de 2 LG Muziq LX570 Keypad Replacement, Rear Case: paso 3, imagen 2 de 2
    • Use the spudger to lift up the two screw covers at the top of the phone.
    • Remove all four Phillips#00 (3.3mm) screws with screwdriver.
  4. LG Muziq LX570 Keypad Replacement: paso 4, imagen 1 de 3 LG Muziq LX570 Keypad Replacement: paso 4, imagen 2 de 3 LG Muziq LX570 Keypad Replacement: paso 4, imagen 3 de 3
    • Use the spudger to lift up the rear case from the phone.
    • Note: Rear case is connected on all sides and will have to be detached on all sides before removal.
    • Remove the rear case from the device.
  5. LG Muziq LX570 Keypad Replacement, Motherboard: paso 5, imagen 1 de 3 LG Muziq LX570 Keypad Replacement, Motherboard: paso 5, imagen 2 de 3 LG Muziq LX570 Keypad Replacement, Motherboard: paso 5, imagen 3 de 3
    • Use the spudger to lift the motherboard from the phone.
  6. LG Muziq LX570 Keypad Replacement, Keypad: paso 6, imagen 1 de 3 LG Muziq LX570 Keypad Replacement, Keypad: paso 6, imagen 2 de 3 LG Muziq LX570 Keypad Replacement, Keypad: paso 6, imagen 3 de 3
    • Caution: The circuit board is connected via ribbon to the phone. Do not break this connection.
    • Note: The circuit board is attached by clips on both sides of the board. Detach each clip before removing the motherboard from the phone.
    • Use the spudger to detach the circuit board from the phone.
  7. LG Muziq LX570 Keypad Replacement: paso 7, imagen 1 de 3 LG Muziq LX570 Keypad Replacement: paso 7, imagen 2 de 3 LG Muziq LX570 Keypad Replacement: paso 7, imagen 3 de 3
    • Open the phone to expose the keypad.
    • Use your finger to push the keypad from the front towards the circuit board.
    • Remove the keypad from the phone.
Conclusión
Braden Burk
Miembro Desde 01/22/12
1 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 3-29, Amido Winter 2012 Miembro de Cal Poly, Team 3-29, Amido Winter 2012
CPSU-AMIDO-W12S3G29
4 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 6
Ultimos 30 días: 11
Todo El Tiempo: 704
