Saltar al contenido principal
LG Motion 4G MS770 Rear Facing Camera Replacement
Qué necesitas
  1. LG Motion 4G MS770 Rear Facing Camera Replacement, Remove the phone's back cover.: paso 1, imagen 1 de 1
    • Use a plastic opening tool to remove the back cover.
  2. LG Motion 4G MS770 Rear Facing Camera Replacement, Remove the battery.: paso 2, imagen 1 de 1
    • Use a plastic opening tool to remove the battery, lifting from the bottom right corner.
  3. LG Motion 4G MS770 Rear Facing Camera Replacement, Remove screws.: paso 3, imagen 1 de 1
    • Use a Phillips #00 Screwdriver to remove all eight 4mm screws.
  4. LG Motion 4G MS770 Rear Facing Camera Replacement: paso 4, imagen 1 de 2 LG Motion 4G MS770 Rear Facing Camera Replacement: paso 4, imagen 2 de 2
    • Use a plastic opening tool to remove the back trim by working around all of the edges.
  5. LG Motion 4G MS770 Rear Facing Camera Replacement: paso 5, imagen 1 de 2 LG Motion 4G MS770 Rear Facing Camera Replacement: paso 5, imagen 2 de 2
    • Remove the volume buttons from the side.
  6. LG Motion 4G MS770 Rear Facing Camera Replacement, Speaker: paso 6, imagen 1 de 2 LG Motion 4G MS770 Rear Facing Camera Replacement, Speaker: paso 6, imagen 2 de 2
    • Use a plastic opening tool to lift the speaker off by prying under the silver square as shown.
    • Note: There is a small tab underneath the speaker that will be lifted off when the speaker is removed.
  7. LG Motion 4G MS770 Rear Facing Camera Replacement, Rear Facing Camera: paso 7, imagen 1 de 1
    • Pry slightly underneath the tab attached to the camera until it pops off.
  8. LG Motion 4G MS770 Rear Facing Camera Replacement: paso 8, imagen 1 de 1
    Herramienta utilizada en este paso:
    Comprar
    • Use tweezers to remove the camera, you will need to use some force as it is glued on.
Conclusión
Una persona más ha completado esta guía.
Zarna Patel
Miembro Desde 10/08/14
320 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 14-1, Leahy Fall 2014 Miembro de USF Tampa, Team 14-1, Leahy Fall 2014
USFT-LEAHY-F14S14G1
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 8
Todo El Tiempo: 224
