Saltar al contenido principal
LG Motion 4G MS770 Motherboard Replacement
Qué necesitas
  1. LG Motion 4G MS770 Motherboard Replacement, Remove the phone's back cover.: paso 1, imagen 1 de 1
    • Use a plastic opening tool to remove the back cover.
  2. LG Motion 4G MS770 Motherboard Replacement, Remove the battery.: paso 2, imagen 1 de 1
    • Use a plastic opening tool to remove the battery, lifting from the bottom right corner.
  3. LG Motion 4G MS770 Motherboard Replacement, Remove screws.: paso 3, imagen 1 de 1
    • Use a Phillips #00 Screwdriver to remove all eight 4mm screws.
  4. LG Motion 4G MS770 Motherboard Replacement: paso 4, imagen 1 de 2 LG Motion 4G MS770 Motherboard Replacement: paso 4, imagen 2 de 2
    • Use a plastic opening tool to remove the back trim by working around all of the edges.
  5. LG Motion 4G MS770 Motherboard Replacement: paso 5, imagen 1 de 2 LG Motion 4G MS770 Motherboard Replacement: paso 5, imagen 2 de 2
    • Remove the volume buttons from the side.
  6. LG Motion 4G MS770 Motherboard Replacement, Speaker: paso 6, imagen 1 de 2 LG Motion 4G MS770 Motherboard Replacement, Speaker: paso 6, imagen 2 de 2
    • Use a plastic opening tool to lift the speaker off by prying under the silver square as shown.
    • Note: There is a small tab underneath the speaker that will be lifted off when the speaker is removed.
  7. LG Motion 4G MS770 Motherboard Replacement, Rear Facing Camera: paso 7, imagen 1 de 1
    • Pry slightly underneath the tab attached to the camera until it pops off.
  8. LG Motion 4G MS770 Motherboard Replacement: paso 8, imagen 1 de 1
    • Use tweezers to remove the camera, you will need to use some force as it is glued on.
  9. LG Motion 4G MS770 Motherboard Replacement, Motherboard: paso 9, imagen 1 de 1
    • Pry off the circled tabs using a plastic opening tool to release the motherboard.
  10. LG Motion 4G MS770 Motherboard Replacement: paso 10, imagen 1 de 1
    • Lift the motherboard off of the phone. It should come right out.
Conclusión
7 personas más completaron esta guía.
Zarna Patel
Miembro Desde 10/08/14
320 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 14-1, Leahy Fall 2014 Miembro de USF Tampa, Team 14-1, Leahy Fall 2014
USFT-LEAHY-F14S14G1
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 3
Todo El Tiempo: 1,291
