Introducción
This guide will show you how to replace a motherboard in your LG Leon LTE.
Partes
No se requieren partes.
  1. Turn the phone over so the back is facing upward. Turn the phone over so the back is facing upward.
    • Turn the phone over so the back is facing upward.
  2. Insert your opening tool in the incision at the bottom center of the phone. Push upward with the opening tool to pry the back of the phone open. Remove the back completely and set aside.
    • Insert your opening tool in the incision at the bottom center of the phone.
    • Push upward with the opening tool to pry the back of the phone open.
    • Remove the back completely and set aside.
  3. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  4. Using the Phillips #0 screwdriver, unscrew the 8 screws that secure the back frame to the body of the phone. Remember to put the screws in a safe place so you don't lose them. Once all screws are removed, use the opening tool to pry the back frame of the phone free.
    • Using the Phillips #0 screwdriver, unscrew the 8 screws that secure the back frame to the body of the phone.
    • Remember to put the screws in a safe place so you don't lose them.
    • Once all screws are removed, use the opening tool to pry the back frame of the phone free.
  5. Using the opening tool, gently pry the phone's earpiece off. Set aside. Separate the old motherboard from the phone fixture by pulling it apart.
    • Using the opening tool, gently pry the phone's earpiece off. Set aside.
    • Separate the old motherboard from the phone fixture by pulling it apart.
    • Gently press the replacement motherboard into the phone fixture.
Conclusión
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 6
Últimos 30 Días: 18
Todo El Tiempo: 274
