Saltar al contenido principal
Introducción
This guide will teach you how to remove the battery from the LG LX160
  1. Place the phone on a flat surface with the back facing upward.
    • Place the phone on a flat surface with the back facing upward.
    • Remove the back panel by placing your thumb on the LG logo and sliding the panel in a downward motion until the panel is removed.
  2. Once the panel is removed, you will see the battery.  Remove the battery by sliding your finger into the notch where the LG logo was on the panel and lift the battery.
    • Once the panel is removed, you will see the battery. Remove the battery by sliding your finger into the notch where the LG logo was on the panel and lift the battery.
  3. Remove the battery completely from the phone and place the battery off to the side.
    • Remove the battery completely from the phone and place the battery off to the side.
Conclusión
David Baruela
Miembro Desde 14/01/10
1 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 11-2, Forte Winter 2010 Miembro de Cal Poly, Team 11-2, Forte Winter 2010
CPSU-FORTE-W10S11G2
5 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 2,152
