Saltar al contenido principal
Introducción
Use this guide to remove the LG LX150's sceen.
Partes
No se especificaron partes.
  1. Use the spudger to pry out the indicated rubber squares. Use the #0 Phillips screwdriver to take out the revealed screws. Use the #0 Phillips screwdriver to take out the revealed screws.
    • Use the spudger to pry out the indicated rubber squares.
    • Use the #0 Phillips screwdriver to take out the revealed screws.
  2. Kits de Reparación de Batería de iPhone
    Sólo $29.99
    Buy Now
    Sólo $29.99
    Buy Now
  3. Carefully lodge the spudger between the face plate and the hinge mechanism. Gently pry the face plate until it releases from place holders. Gently pry the face plate until it releases from place holders.
    • Carefully lodge the spudger between the face plate and the hinge mechanism.
    • Gently pry the face plate until it releases from place holders.
  4. Apply even amounts of force upon removing screen, otherwise cracking may occur. Gently loosen the screen from its adhesive by pressing around the screen's rear perimeter with a spudger. Place upward pressure in crevices between face plate and screen.
    • Apply even amounts of force upon removing screen, otherwise cracking may occur.
    • Gently loosen the screen from its adhesive by pressing around the screen's rear perimeter with a spudger. Place upward pressure in crevices between face plate and screen.
    • Carefully use both thumbs and apply pressure to the back of the screen to pop out.
Conclusión
Una persona más ha completado esta guía.
Tye Barba
Miembro Desde 15/04/10
88 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 10-44, Garner Spring 2010 Miembro de Cal Poly, Team 10-44, Garner Spring 2010
CPSU-GARNER-S10S10G44
4 Miembros
18 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 3
Todo El Tiempo: 1,251
