Saltar al contenido principal
LG LX150 Keypad Replacement
Qué necesitas
  1. LG LX150 Keypad Replacement, Back Cover: paso 1, imagen 1 de 3 LG LX150 Keypad Replacement, Back Cover: paso 1, imagen 2 de 3 LG LX150 Keypad Replacement, Back Cover: paso 1, imagen 3 de 3
    • First locate the button and the bottom of the cover where the arrow is. Press down on the button.
    • While pushing down on the button, slide the cover up towards the hinge until the cover comes off.
    • The battery will be visible after removing the back cover.
  2. LG LX150 Keypad Replacement, Battery: paso 2, imagen 1 de 2 LG LX150 Keypad Replacement, Battery: paso 2, imagen 2 de 2
    • Simultaneously push the battery forward and pull up from the bottom.
  3. LG LX150 Keypad Replacement: paso 3, imagen 1 de 1
    • Once the battery is loose it can be easily removed. The phone's ID tag will be visible once the battery is removed.
    • Be careful of damaged or leaking batteries. If your battery appears damaged, remove it with care and find a replacement.
  4. LG LX150 Keypad Replacement, Internal Back Cover: paso 4, imagen 1 de 3 LG LX150 Keypad Replacement, Internal Back Cover: paso 4, imagen 2 de 3 LG LX150 Keypad Replacement, Internal Back Cover: paso 4, imagen 3 de 3
    • Remove the 7 phillips screws indicated by the red arrows using the phillips #0 screwdriver.
    • Insert the flat end of the spudger in-between the black and blue phone casing on the side of the phone and split the the blue and black apart. Work your way around the perimeter of the cover, loosening all corners.
  5. LG LX150 Keypad Replacement: paso 5, imagen 1 de 2 LG LX150 Keypad Replacement: paso 5, imagen 2 de 2
    • Remove the internal back cover after loosening all the corners.
    • The second picture below is what you will see after removing the internal back cover.
  6. LG LX150 Keypad Replacement, Motherboard: paso 6, imagen 1 de 1
    • Lift the motherboard from the bottom to loosen it.
  7. LG LX150 Keypad Replacement: paso 7, imagen 1 de 1
    • Remove the pin socket that connects the screen to the motherboard by pulling up away from the motherboard.
  8. LG LX150 Keypad Replacement: paso 8, imagen 1 de 2 LG LX150 Keypad Replacement: paso 8, imagen 2 de 2
    • Remove the motherboard.
    • The keypad will now be visible, as shown in the second picture.
  9. LG LX150 Keypad Replacement, Keypad: paso 9, imagen 1 de 1
    • To remove the key pad, simply pull it off from the LG LX150 frame.
  10. LG LX150 Keypad Replacement: paso 10, imagen 1 de 1
    • When the key pad is removed, the frame will be all that is left.
    • If you wish to replace the key pad, place the new keypad on to the frame and reassemble the phone to resume use.
Conclusión
Una persona más ha completado esta guía.
Andrea
Miembro Desde 04/19/10
110 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 10-44, Garner Spring 2010 Miembro de Cal Poly, Team 10-44, Garner Spring 2010
CPSU-GARNER-S10S10G44
4 Miembros
18 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 919
