Saltar al contenido principal
LG LX150 Battery Replacement
  1. LG LX150 Battery Replacement, Back Cover: paso 1, imagen 1 de 3 LG LX150 Battery Replacement, Back Cover: paso 1, imagen 2 de 3 LG LX150 Battery Replacement, Back Cover: paso 1, imagen 3 de 3
    • First locate the button and the bottom of the cover where the arrow is. Press down on the button.
    • While pushing down on the button, slide the cover up towards the hinge until the cover comes off.
    • The battery will be visible after removing the back cover.
  2. LG LX150 Battery Replacement, Battery: paso 2, imagen 1 de 2 LG LX150 Battery Replacement, Battery: paso 2, imagen 2 de 2
    • Simultaneously push the battery forward and pull up from the bottom.
  3. LG LX150 Battery Replacement: paso 3, imagen 1 de 1
    • Once the battery is loose it can be easily removed. The phone's ID tag will be visible once the battery is removed.
    • Be careful of damaged or leaking batteries. If your battery appears damaged, remove it with care and find a replacement.
Conclusión
Una persona más ha completado esta guía.
Andrea
Miembro Desde 04/19/10
110 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 10-44, Garner Spring 2010 Miembro de Cal Poly, Team 10-44, Garner Spring 2010
CPSU-GARNER-S10S10G44
4 Miembros
18 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 1,415
