Saltar al contenido principal
LG LMWS27626S French 4 Door Refrigerator Water Filter Replacement
Qué necesitas
  1. LG LMWS27626S French 4 Door Refrigerator Water Filter Replacement, Filter: paso 1, imagen 1 de 3 LG LMWS27626S French 4 Door Refrigerator Water Filter Replacement, Filter: paso 1, imagen 2 de 3 LG LMWS27626S French 4 Door Refrigerator Water Filter Replacement, Filter: paso 1, imagen 3 de 3
    • Find a replacement water filter based on the model number for your fridge.
    • You can also bring your old water filter to a store to get a suitable replacement that way.
  2. LG LMWS27626S French 4 Door Refrigerator Water Filter Replacement: paso 2, imagen 1 de 3 LG LMWS27626S French 4 Door Refrigerator Water Filter Replacement: paso 2, imagen 2 de 3 LG LMWS27626S French 4 Door Refrigerator Water Filter Replacement: paso 2, imagen 3 de 3
    • For the best result, it's best to buy the original filter that was made for the fridge as opposed to an aftermarket water filter.
    • Remove the water filter from the box .
    • Remove the cap from the water filter.
  3. LG LMWS27626S French 4 Door Refrigerator Water Filter Replacement: paso 3, imagen 1 de 3 LG LMWS27626S French 4 Door Refrigerator Water Filter Replacement: paso 3, imagen 2 de 3 LG LMWS27626S French 4 Door Refrigerator Water Filter Replacement: paso 3, imagen 3 de 3
    • Open the water filter bay in the top left corner of the fridge.
    • Remove the existing water filter inside. Or, if your fridge doesn't yet have a water filter, remove the green cap instead.
  4. LG LMWS27626S French 4 Door Refrigerator Water Filter Replacement: paso 4, imagen 1 de 3 LG LMWS27626S French 4 Door Refrigerator Water Filter Replacement: paso 4, imagen 2 de 3 LG LMWS27626S French 4 Door Refrigerator Water Filter Replacement: paso 4, imagen 3 de 3
    • Angle the receiver in the fridge downward so that the filter is easy to plug in.
    • Firmly press the water filter into the receiver until it is snug and attached.
    • If the water filter falls out once you let go, you simply need to press harder into the receiver.
  5. LG LMWS27626S French 4 Door Refrigerator Water Filter Replacement: paso 5, imagen 1 de 2 LG LMWS27626S French 4 Door Refrigerator Water Filter Replacement: paso 5, imagen 2 de 2
    • Shut the water filter cover.
  6. LG LMWS27626S French 4 Door Refrigerator Water Filter Replacement: paso 6, imagen 1 de 1
    • Purge the system by dispensing water for about 2-3 minutes, or until you have cycled through approximately 64 ounces.
    • Your water should now be clean and crystal clear!
Linea de Meta
Una persona más ha completado esta guía.
Luc Charles
Miembro Desde 03/22/21
154 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 19
Ultimos 30 días: 103
Todo El Tiempo: 6,656
