Saltar al contenido principal
LG L1200 Logic Board Replacement
Qué necesitas
  1. LG L1200 Logic Board Replacement, Logic Board: paso 1, imagen 1 de 1
    • Make sure you remove the battery by lifting the tab on the back of the phone before opening the case.
    • Poke out rubber covers using a spudger or pointy object, such as a thumb tack.
  2. LG L1200 Logic Board Replacement: paso 2, imagen 1 de 1
    • Use a T6 torx screwdriver to unscrew the 6 screws that hold the back casing on.
  3. LG L1200 Logic Board Replacement: paso 3, imagen 1 de 1
    • Use IPod opening tool to separate back housing.
    • There are two tabs located on either side of the phone.
  4. LG L1200 Logic Board Replacement: paso 4, imagen 1 de 1
    • Separate the back housing from the phone.
    • Be careful not to rip out the wire (highlighted in yellow) when separating the back housing.
  5. LG L1200 Logic Board Replacement: paso 5, imagen 1 de 1
    • Use a spudger to disconnect antenna wire.
  6. LG L1200 Logic Board Replacement: paso 6, imagen 1 de 1
    • Use the IPod opening tool to pop out the logic board.
  7. LG L1200 Logic Board Replacement: paso 7, imagen 1 de 1
    • Use the IPod opening tool to disconnect the main ribbon.
  8. LG L1200 Logic Board Replacement: paso 8, imagen 1 de 1
    • Once the ribbon is detached, remove the logic board and replace if necessary.
Conclusión
Joshua Herrmann
Miembro Desde 04/16/10
8 Reputación
8 Guías creadas
Equipo
Cal Poly, Team 6-14, Maness Spring 2010 Miembro de Cal Poly, Team 6-14, Maness Spring 2010
CPSU-MANESS-S10S6G14
4 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 1,210
