Saltar al contenido principal
LG L1200 Inner LCD Screen Replacement
Qué necesitas
  1. LG L1200 Inner LCD Screen Replacement, Inner LCD Screen: paso 1, imagen 1 de 1
    • Make sure you remove the battery by lifting the tab on the back of the phone before opening the case.
    • Flip open the phone and locate the four screw covers.
  2. LG L1200 Inner LCD Screen Replacement: paso 2, imagen 1 de 1
    • Remove all four screw covers by using an IPod opening tool. They should come off relatively easy.
  3. LG L1200 Inner LCD Screen Replacement: paso 3, imagen 1 de 1
    • Using a T6 Torx screwdriver, remove all four screws.
  4. LG L1200 Inner LCD Screen Replacement: paso 4, imagen 1 de 3 LG L1200 Inner LCD Screen Replacement: paso 4, imagen 2 de 3 LG L1200 Inner LCD Screen Replacement: paso 4, imagen 3 de 3
    • Once the screws are removed, use an IPod opening tool to separate the front cover from the inner screen cover.
    • Run the Ipod opening tool down both sides,disconnecting the tabs that hold the covers together.
  5. LG L1200 Inner LCD Screen Replacement: paso 5, imagen 1 de 2 LG L1200 Inner LCD Screen Replacement: paso 5, imagen 2 de 2
    • Pull the inner screen cover towards you and up in order to separate it from the front cover.
  6. LG L1200 Inner LCD Screen Replacement: paso 6, imagen 1 de 1
    • Remove the tape from the bottom of the LCD screen.
  7. LG L1200 Inner LCD Screen Replacement: paso 7, imagen 1 de 3 LG L1200 Inner LCD Screen Replacement: paso 7, imagen 2 de 3 LG L1200 Inner LCD Screen Replacement: paso 7, imagen 3 de 3
    • Carefully lift the LCD screen and peel it from the gold ribbon. The sticky connection runs all the way around the LCD screen.
  8. LG L1200 Inner LCD Screen Replacement: paso 8, imagen 1 de 3 LG L1200 Inner LCD Screen Replacement: paso 8, imagen 2 de 3 LG L1200 Inner LCD Screen Replacement: paso 8, imagen 3 de 3
    • Flip the screen over so that you can see the outer LCD screen and the circuit board.
    • Insert spudger in the bottom right corner.
    • Lift up and move the spudger across the bottom.
    • The third photo is rotated 180 degrees.
  9. LG L1200 Inner LCD Screen Replacement: paso 9, imagen 1 de 2 LG L1200 Inner LCD Screen Replacement: paso 9, imagen 2 de 2
    • Use the pointy side of the spudger to peel off the interior tape.
    • Flip the assembly over and peel the circuit board from the screen.
  10. LG L1200 Inner LCD Screen Replacement: paso 10, imagen 1 de 2 LG L1200 Inner LCD Screen Replacement: paso 10, imagen 2 de 2
    • Use the spudger to remove the LCD screen from its backing.
Conclusión
Joshua Herrmann
Miembro Desde 04/16/10
8 Reputación
8 Guías creadas
Equipo
Cal Poly, Team 6-14, Maness Spring 2010 Miembro de Cal Poly, Team 6-14, Maness Spring 2010
CPSU-MANESS-S10S6G14
4 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 13
Todo El Tiempo: 2,224
