Saltar al contenido principal
LG L1200 External Housing Replacement
Qué necesitas
  1. LG L1200 External Housing Replacement, Inner LCD Screen: paso 1, imagen 1 de 1
    • Make sure you remove the battery by lifting the tab on the back of the phone before opening the case.
    • Flip open the phone and locate the four screw covers.
  2. LG L1200 External Housing Replacement: paso 2, imagen 1 de 1
    • Remove all four screw covers by using an IPod opening tool. They should come off relatively easy.
  3. LG L1200 External Housing Replacement: paso 3, imagen 1 de 1
    • Using a T6 Torx screwdriver, remove all four screws.
  4. LG L1200 External Housing Replacement: paso 4, imagen 1 de 3 LG L1200 External Housing Replacement: paso 4, imagen 2 de 3 LG L1200 External Housing Replacement: paso 4, imagen 3 de 3
    • Once the screws are removed, use an IPod opening tool to separate the front cover from the inner screen cover.
    • Run the Ipod opening tool down both sides,disconnecting the tabs that hold the covers together.
  5. LG L1200 External Housing Replacement: paso 5, imagen 1 de 2 LG L1200 External Housing Replacement: paso 5, imagen 2 de 2
    • Pull the inner screen cover towards you and up in order to separate it from the front cover.
  6. LG L1200 External Housing Replacement: paso 6, imagen 1 de 1
    • Remove the tape from the bottom of the LCD screen.
  7. LG L1200 External Housing Replacement: paso 7, imagen 1 de 3 LG L1200 External Housing Replacement: paso 7, imagen 2 de 3 LG L1200 External Housing Replacement: paso 7, imagen 3 de 3
    • Carefully lift the LCD screen and peel it from the gold ribbon. The sticky connection runs all the way around the LCD screen.
  8. LG L1200 External Housing Replacement: paso 8, imagen 1 de 3 LG L1200 External Housing Replacement: paso 8, imagen 2 de 3 LG L1200 External Housing Replacement: paso 8, imagen 3 de 3
    • Flip the screen over so that you can see the outer LCD screen and the circuit board.
    • Insert spudger in the bottom right corner.
    • Lift up and move the spudger across the bottom.
    • The third photo is rotated 180 degrees.
  9. LG L1200 External Housing Replacement: paso 9, imagen 1 de 2 LG L1200 External Housing Replacement: paso 9, imagen 2 de 2
    • Use the pointy side of the spudger to peel off the interior tape.
    • Flip the assembly over and peel the circuit board from the screen.
  10. LG L1200 External Housing Replacement: paso 10, imagen 1 de 2 LG L1200 External Housing Replacement: paso 10, imagen 2 de 2
    • Use the spudger to remove the LCD screen from its backing.
  11. LG L1200 External Housing Replacement, Camera: paso 11, imagen 1 de 1
    • Carefully slide the spudger behind the main ribbon in order to separate it from the inside cover of the phone.
  12. LG L1200 External Housing Replacement: paso 12, imagen 1 de 2 LG L1200 External Housing Replacement: paso 12, imagen 2 de 2
    • Use a spudger to pop off the camera ribbon from the main ribbon. The camera component should separate entirely.
  13. LG L1200 External Housing Replacement, Logic Board: paso 13, imagen 1 de 1
    • Poke out rubber covers using a spudger or pointy object, such as a thumb tack.
  14. LG L1200 External Housing Replacement: paso 14, imagen 1 de 1
    • Use a T6 torx screwdriver to unscrew the 6 screws that hold the back casing on.
  15. LG L1200 External Housing Replacement: paso 15, imagen 1 de 1
    • Use IPod opening tool to separate back housing.
    • There are two tabs located on either side of the phone.
  16. LG L1200 External Housing Replacement: paso 16, imagen 1 de 1
    • Separate the back housing from the phone.
    • Be careful not to rip out the wire (highlighted in yellow) when separating the back housing.
  17. LG L1200 External Housing Replacement: paso 17, imagen 1 de 1
    • Use a spudger to disconnect antenna wire.
  18. LG L1200 External Housing Replacement: paso 18, imagen 1 de 1
    • Use the IPod opening tool to pop out the logic board.
  19. LG L1200 External Housing Replacement: paso 19, imagen 1 de 1
    • Use the IPod opening tool to disconnect the main ribbon.
  20. LG L1200 External Housing Replacement: paso 20, imagen 1 de 1
    • Once the ribbon is detached, remove the logic board and replace if necessary.
  21. LG L1200 External Housing Replacement, Keypad: paso 21, imagen 1 de 1
    • The back of the keypad is shown here, next to the logic board (the logic board is turned over to expose the buttons).
  22. LG L1200 External Housing Replacement: paso 22, imagen 1 de 2 LG L1200 External Housing Replacement: paso 22, imagen 2 de 2
    • Using a spudger, lift the keypad off of the tabs.
  23. LG L1200 External Housing Replacement, External Housing: paso 23, imagen 1 de 1
    • Wedge a spudger or another harder prying tool in the connection between the top cover and the bottom cover on the right side.
    • Use a large amount of force to push the top cover off the bottom cover's blue extrusion.
    • Too much force may break the plastic of the top cover
    • When separating the top cover from the bottom cover, be careful not to tear the ribbon as you pull it out from the hinge.
  24. LG L1200 External Housing Replacement: paso 24, imagen 1 de 2 LG L1200 External Housing Replacement: paso 24, imagen 2 de 2
    • Slide the ribbon out of the slot in the joint on the left side.
    • Pull the ribbon out of the top cover with your hand.
    • Once the ribbon is removed, you can replace the covers.
Conclusión
Joshua Herrmann
Miembro Desde 04/16/10
8 Reputación
8 Guías creadas
Equipo
Cal Poly, Team 6-14, Maness Spring 2010 Miembro de Cal Poly, Team 6-14, Maness Spring 2010
CPSU-MANESS-S10S6G14
4 Miembros
16 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 13
Todo El Tiempo: 1,160
