Saltar al contenido principal
LG KP100 Battery Replacement
  1. LG KP100 Battery Replacement, Battery: paso 1, imagen 1 de 2 LG KP100 Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Begin by taking the back battery cover off.
    • Put your index finger on the white notch and apply pressure.
    • While applying pressure, move your hand backwards to slide the battery cover off of the body of the phone.
  2. LG KP100 Battery Replacement: paso 2, imagen 1 de 2 LG KP100 Battery Replacement: paso 2, imagen 2 de 2
    • Remove the battery.
    • Put your index finger in the notch above the battery near the top of the casing.
    • While applying pressure against the battery, lift up and take out the battery.
Conclusión
Preston Brown
Miembro Desde 04/12/12
28 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 6-20, Amido Spring 2012 Miembro de Cal Poly, Team 6-20, Amido Spring 2012
CPSU-AMIDO-S12S6G20
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 1,138
