Introducción
Your rear camera may be broken, cracked, or otherwise not working. This guide will instruct you on how to remove your faulty rear camera.
Qué necesitas
Place a fingernail in slot at in the bottom edge of the phone.
Pull up on the back panel while holding down the rest of the phone steady with your hand.
Remove the 9 frame screws with a JIS #00 screwdriver.
Pop the camera button frame off with a spudger. The home button should come off along with the frame.
Insert the edge of a plastic opening tool underneath the camera connector that is attached to the camera by a flat, thin, and flexible sheet.
Slowly lever the connector free by pressing down on the opening tool's handle. The connector should be fairly solid and pop out by levering just one edge.
Una persona más ha completado esta guía.
