Saltar al contenido principal
LG K7 Motherboard Replacement
Qué necesitas
  1. LG K7 Motherboard Replacement, Motherboard: paso 1, imagen 1 de 3 LG K7 Motherboard Replacement, Motherboard: paso 1, imagen 2 de 3 LG K7 Motherboard Replacement, Motherboard: paso 1, imagen 3 de 3
    • Place phone face-down and use your nail to pry the back off the back.
  2. LG K7 Motherboard Replacement: paso 2, imagen 1 de 2 LG K7 Motherboard Replacement: paso 2, imagen 2 de 2
    • Use a plastic spudger or your nail to lift the battery out of the device and put it to the side.
    • The battery should lift out with little effort. If it does not, do not force it.
  3. LG K7 Motherboard Replacement: paso 3, imagen 1 de 3 LG K7 Motherboard Replacement: paso 3, imagen 2 de 3 LG K7 Motherboard Replacement: paso 3, imagen 3 de 3
    • Use a Phillips #0 screwdriver to remove the single 3.5 mm screw holding the power button and volume rocker in place and lift it out and put it to the side.
  4. LG K7 Motherboard Replacement: paso 4, imagen 1 de 3 LG K7 Motherboard Replacement: paso 4, imagen 2 de 3 LG K7 Motherboard Replacement: paso 4, imagen 3 de 3
    • Use a Phillips #0 screwdriver to unscrew the three 3.5mm screws in the bottom portion of the phone and put them to the side.
  5. LG K7 Motherboard Replacement: paso 5, imagen 1 de 3 LG K7 Motherboard Replacement: paso 5, imagen 2 de 3 LG K7 Motherboard Replacement: paso 5, imagen 3 de 3
    • Use a spudger to pry the plastic bit off. Be warned, it will snap out and might fling itself when you attempt prying it out.
  6. LG K7 Motherboard Replacement: paso 6, imagen 1 de 3 LG K7 Motherboard Replacement: paso 6, imagen 2 de 3 LG K7 Motherboard Replacement: paso 6, imagen 3 de 3
    • Use a Phillips #0 screwdriver to unscrew the five 3.5 mm screws holding the housing into the device and use a spudger to pop it out of the back of the device exposing the motherboard.
  7. LG K7 Motherboard Replacement: paso 7, imagen 1 de 3 LG K7 Motherboard Replacement: paso 7, imagen 2 de 3 LG K7 Motherboard Replacement: paso 7, imagen 3 de 3
    • Use a plastic spudger to lift the motherboard out of the casing.
    • You must use a plastic tool for this step or you may risk shorting the logic board.
  8. LG K7 Motherboard Replacement: paso 8, imagen 1 de 3 LG K7 Motherboard Replacement: paso 8, imagen 2 de 3 LG K7 Motherboard Replacement: paso 8, imagen 3 de 3
    • Turn the device over and locate the connector between the digitizer and the motherboard.
    • Use a plastic spudger to disconnect the connector.
  9. LG K7 Motherboard Replacement: paso 9, imagen 1 de 2 LG K7 Motherboard Replacement: paso 9, imagen 2 de 2
    • You have now successfully removed the motherboard from your LG K7.
Conclusión
Una persona más ha completado esta guía.
Equipo
IUPUI, Team S3-G4, Harley Fall 2018 Miembro de IUPUI, Team S3-G4, Harley Fall 2018
IUPUI-HARLEY-F18S3G4
3 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 7
Todo El Tiempo: 812
