Saltar al contenido principal
LG K7 Charging Port Replacement
Qué necesitas
  1. LG K7 Charging Port Replacement, Charging Port: paso 1, imagen 1 de 2 LG K7 Charging Port Replacement, Charging Port: paso 1, imagen 2 de 2
    • Remove the back cover by using the plastic opening tool.
    • Remove battery by using the plastic opening tool.
  2. LG K7 Charging Port Replacement: paso 2, imagen 1 de 1
    • Remove the nine 4mm Phillips #000 screws.
    • The cover should lift off easily once the screws are out.
    • Be gentle with the frame when removing it. The plastic is very thin and can easily break.
  3. LG K7 Charging Port Replacement: paso 3, imagen 1 de 1
    • Place the plastic opening tool between the screen and the plastic edge of the phone and pry carefully until screen pops off.
    • The frame is held to the rest of the phone with plastic tabs. Release each tab one at a time around the phone for the easiest removal.
    • Do not bend the outer frame or screen when separating them. This will severely damage the phone.
  4. LG K7 Charging Port Replacement: paso 4, imagen 1 de 1
    • Place the plastic opening tool between the blue motherboard and black plate and pry until the motherboard pops off.
  5. LG K7 Charging Port Replacement: paso 5, imagen 1 de 2 LG K7 Charging Port Replacement: paso 5, imagen 2 de 2
    • Heat up the four connection points using a soldering iron.
    • Once hot, gently push the port off.
    • Soldering iron is hot! Use with caution.
    • Be careful not to touch other components with the soldering iron.
Conclusión
Una persona más ha completado esta guía.
Stephen Damm
Miembro Desde 11/07/19
167 Reputación
1 Guía escrita
Equipo
IUPUI, Team S3-G2, Harley Fall 2019 Miembro de IUPUI, Team S3-G2, Harley Fall 2019
IUPUI-HARLEY-F19S3G2
3 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 6
Todo El Tiempo: 559
