Saltar al contenido principal
LG K30 Motherboard Replacement
Qué necesitas
  1. LG K30 Motherboard Replacement, Battery: paso 1, imagen 1 de 2 LG K30 Motherboard Replacement, Battery: paso 1, imagen 2 de 2
    • Before disassembling your LG K30, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your Phone before beginning disassembly.
    • Use the 'Jimmy' and 'Metal Spudger' to slowly pry open the outsides of the back case.
  2. LG K30 Motherboard Replacement: paso 2, imagen 1 de 1
    • Remove the thirteen 3.4 mm Phillips #00 screws securing the midframe to the display assembly.
  3. LG K30 Motherboard Replacement: paso 3, imagen 1 de 1
    • Use a metal spudger or plastic opening tool to pry open the outer cover.
  4. LG K30 Motherboard Replacement: paso 4, imagen 1 de 1
    • Use the flat end of a spudger to detach the battery connector from the logic board.
  5. LG K30 Motherboard Replacement: paso 5, imagen 1 de 2 LG K30 Motherboard Replacement: paso 5, imagen 2 de 2
    • Use a spudger to pry the battery from the phone.
    • There may be an adhesive on the back of the battery and the phone. Pry the battery gently to prevent puncture or damage.
    • Do not bend or puncture the battery.
  6. LG K30 Motherboard Replacement, Motherboard: paso 6, imagen 1 de 1
    • Use a spudger to carefully disconnect the front camera connector.
    • Use a spudger to disconnect the display cable connector.
  7. LG K30 Motherboard Replacement: paso 7, imagen 1 de 2 LG K30 Motherboard Replacement: paso 7, imagen 2 de 2
    • Remove the motherboard assembly from the display assembly with the a spudger or hand.
Conclusión
4 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 15
Todo El Tiempo: 1,982
