Introducción
If the phone's volume will not increase/decrease or the buttons are not functioning properly, use this guide to replace your volume buttons.
Qué necesitas
Remove the thirteen 5mm screws holding the plastic shield covering the motherboard using the Phillips #00 screwdriver.
Carefully use the plastic opening tool to pry the ribbon cable connecting the battery to the motherboard of the phone.
Slowly pull the ribbon cable upward releasing the volume buttons from the phone.
