Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
LG Intuition Battery Replacement
Qué necesitas
  1. LG Intuition Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Turn the device so the two bottom screws are shown.
  2. LG Intuition Battery Replacement: paso 2, imagen 1 de 1
    • Remove the two 7mm screws holding the back panel of the phone using the P5 bit and magnetic driver.
  3. LG Intuition Battery Replacement: paso 3, imagen 1 de 1
    • Carefully use the plastic opening tool to pry the back panel of the phone from the front screen. This will expose the battery and other parts.
  4. LG Intuition Battery Replacement: paso 4, imagen 1 de 1
    • Use the Phillips #0 screwdriver to remove the 5mm screw holding the metal bracket that protects the battery's ribbon cable.
  5. LG Intuition Battery Replacement: paso 5, imagen 1 de 1
    • Carefully use the plastic opening tool to pry the ribbon cable connecting the battery to the motherboard of the phone.
  6. LG Intuition Battery Replacement: paso 6, imagen 1 de 2 LG Intuition Battery Replacement: paso 6, imagen 2 de 2
    • Gently raise the battery from its compartment.
Conclusión
Una persona más ha completado esta guía.
Equipo
UMass Dartmouth, Team S3-G4, Peak Fall 2018 Miembro de UMass Dartmouth, Team S3-G4, Peak Fall 2018
UMASSD-PEAK-F18S3G4
Miembros de 3
6 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 9
Ultimos 30 días: 34
Todo El Tiempo: 502
